Strut Bolt Problem
Strut Bolt Problem
Got a problem. I went out to hook up my grounding cable set and found out that one of the bolts holding on my strut bar can't be removed by conventional means. The bolt is spinning when I try to remove the nut with a socket wrench. I can get my hand up underneath, right above the spring, and can feel the smooth head spinning around when I turn it. Any ideas on how to get the damn thing to hold still so I can take off the nut? I'm going to be putting on new springs soon so it's gotta come off...not to mention the fact that my suspension is not solid!
Originally Posted by hanahawaiian
Use the Grip Jaw lock on bottom then top use socket to take bolt off. Try it I think it will work
Originally Posted by h8yourv8
You talking about the bolt in the center? It's not gunna come off until you remove the pressure of the springs with a spring compresure.
The bolt should come out just as easily as when you removed it to put on your strut bar! Dunno why it's being difficult this time around. Prolly cuz you're trying to install something else.
MitsuJoe
468
Feb 20, 2016 11:17 AM
undercoverpope
20
Jul 20, 2011 10:54 AM
MitsuJoe
Aug 1, 2004 01:59 PM
