My shifting is getting rough.... any ideas?
I've been noticing lately that shifting is getting a little rougher. Sometimes the gears grind a bit (or synchros) even when i have the clutch fully in. Sometimes its almost impossible to get it into first of second gear. I feel like I am going to snap my shifter in half. ANyone have any ideas what could be the problem if there is one? Do I need to make an appointment with Mitsu? THanks in advance for your help.
do you have a short shifter? if you do, over time the lube starts to wear off and you have to re-apply it. I've also noticed in cold weather, it tends to stick when going from first to second. It feels like it gets snagged or the clutch didn't fully dissengage.
Don't take it to
Check the fluid. Better yet, take all the fluid out and put in NEW fluid. It's probably just getting old and dirty (and possibly missing some).
I changed mine at 30k and it's made a major difference. Get some Mobil 1 or Red Line gear oil. Then follow instructions.
!Check the fluid. Better yet, take all the fluid out and put in NEW fluid. It's probably just getting old and dirty (and possibly missing some).
i'm having the same problem with my car, especially shifting into 3rd. i'll have the cluch fully engaged and i'll go to shift and it will just grind into gear
, i hate it..
i'll try changing the oil and let you guys know if that helps
, i hate it..i'll try changing the oil and let you guys know if that helps
I've found that my shifting is almost impossible to get into first and second gear when I first start the car in teh morning (sub-freezing temps), but once the car is warm, then its a lot easier.
