Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Can you reset the automatic's computer for shifting gears?
Old Jul 15, 2005 | 04:55 PM
kraziqt's Avatar
Question Can you reset the automatic's computer for shifting gears?
Ok so I'm taking the chance of asking a stupid question, but I thought if anybody had a quick answer it would be you guys. I don't know if its always been this way and I just haven't been paying attention .. or if this is something that gets worse with time but... I realized that my lancer (automatic) changes gears EXTREMELY late. It waits until about 4k RPM's before it will shift gears and it drives me krazi. I know that when you drive the car for the first time, it adjusts to the way you drive it and memorizes it. I bought my lancer new but it was the demo car at the dearlership.. so I'm sure ppl were killin it while they were testing it. So my question is.. is there a way to reprogram the computer so that it shifts gears faster?
Thanks..
Old Jul 15, 2005 | 04:59 PM
Z_Lancer_Man's Avatar
You can always reset the ECU and start the learning over. Disconnect your battery for 15 minutes, reconnect, let it idle for ~10 minutes, then start to drive nicely. It should adjust and re-learn your driving style.
Old Jul 15, 2005 | 07:01 PM
fatboyracing's Avatar
and when you reset the ecu it will take a couple of days to learn the shifting so dont be surprised if your drivin down the road and it doesnt shift the way you want it to . especially with passing and hills like that...
Old Jul 15, 2005 | 07:32 PM
RalliArtI4's Avatar
yeah, disconnect the battery
Old Jul 16, 2005 | 09:57 AM
comatose721's Avatar
when the battery is disconnected, pump the brakes a few times till they get rock hard. that will drain and extra charge and avoid you having to wait longer to start the learning again.
Old Jul 16, 2005 | 10:16 AM
kraziqt's Avatar
thank you so much guys. For the guys that have done this, has it improved your driving signifcantly?? Thanks again guys...
Old Jul 16, 2005 | 11:35 AM
ummm, i drive a 5spd but i guess you could say it helps since i need to reset my PB ECU with every new mod and/or when the weather changes like 30-40 degrees from when i originally set it...either way
Old Jul 16, 2005 | 11:39 AM
pumpdog720's Avatar
It always just shifts depending on how hard I'm driving it. It does not shift at the same place everytime.
Also, if you want it to shift early, just take your foot off the gas and lots of time it will shift to the the next gear.
Old Jul 16, 2005 | 09:41 PM
HobieKopek's Avatar
It'll definitely effect your gas mileage if nothing else. Don't expect huge gains from this. Remember, you're just changing shift points.
Old Jul 19, 2005 | 02:35 PM
kraziqt's Avatar
hey Zlancer .. when u say after letting the car idle to drive "nicely" - what do u mean? do u mean slowly? shouldnt i drive fast to teach the car to shift gears faster?
Old Jul 19, 2005 | 07:38 PM
kraziqt's Avatar
bump
Old Jul 20, 2005 | 07:44 AM
kraziqt's Avatar
morning bump
Old Jul 20, 2005 | 08:48 AM
Just don't floor it or punch it for like 15 minutes, and try to drive under different circumstances like stop and go, highway, on ramp, off ramp, things like that so the ECU can learn the different conditions and create the map. After that you can drive like a krazi woman
Old Jul 20, 2005 | 09:22 AM
TeamAccolade's Avatar
The automatic is not a programed shift. Its learns from how you drive. so after that 15min you need to drive it like you would anyother day. that way it learns your shift points. Other wise it doesn't quite know when to shift.
Old Jul 20, 2005 | 10:52 AM
just for the hell of it once you are done with the learning process, why not stop, turn off that lancer, and restart it to ensure a clean start hahahaha let's just pretend it's a PB ECU....good luck on getting that reset.
