Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Blew My Stage II Clutch Set-Up!!!
Old Sep 30, 2005 | 09:59 PM
  #31
comatose721's Avatar
Originally Posted by rhyzin
for RRM stage 2, looks like they're (they'd better be) using the ACT 95% pressure plate with the organic clutch good for 320 lbs of torque. seem like a good street setup. can take more abuse than most of us are ever gonna give it.
when i get my camera back i'll post pics of the ACT stage II that i blew...the pressure plate is a bit out of line hahaha the fingers don't rest even anymore, there is a groove from where the TOB was rubbing against it from not disengaging, and the disc itself is mangled a bit..one of the springs has a nice notch missing in it (almost snapped the spring) and the others are a little chipped...what i'm trying to get at is...i drove like an a$$ and abused it so it gave out.
these things should be a-hole proof
Old Oct 4, 2005 | 09:46 AM
  #32
HobieKopek's Avatar
Organic faces have smoother engagement. You're pretty much always going to want a spring hub disk in order to reduce driveline shock on any car that you plan on streeting. I would have thought the copper faced 4 puck on my CM stage 4 would be a horribly stiff engagement before I bought it. Turns out it's only slightly more harsh than the stock clutch, but holds power much better. On the other hand it isn't something you want to feather. You're off or you're on. The Ceramic and metal faces pretty are pretty much on/off clutches, the organic faces tend to be more like stock, but they hold a lot less power too.
Yeah, I don't know why CM sells so many stages, but it sure helped to illustrate my point.
Old Oct 4, 2005 | 01:16 PM
  #33
according to the CM site they don't have any clutches for us lancers, only for the Evo's...where did you find yours Hobie?
Old Oct 4, 2005 | 01:26 PM
  #34
Alchemist's Avatar
probably bought one for a 5G Mirage... I think all of their tranny stuff is the same as ours
Old Oct 4, 2005 | 07:04 PM
  #35
HobieKopek's Avatar
I bought one for a 1.8l 5g Mirage. I'm tired of saying this, but I know you're good people coma so I'll say it again, the pressure plate and clutch disc from the 1.8l 5g Mirage fit just fine, but the TO bearing will not. As far as I know I'm the only person who's used a Mirage clutch in his Lancer (despite the fact that I did this and shared the info over 2 years ago), but the options are certainly out there for anyone who wants to take advantage of them.
Old Oct 4, 2005 | 10:00 PM
  #36
thanks
Old Oct 5, 2005 | 12:07 PM
  #37
Evodreamer28's Avatar
I have the stage 3 clutch on cnfx website, I like it very much very smooth, as well the best way to contact cnfx 9 times out of 10 is on aol instant messanger. The shop owners screen name is viperbluz. His name is Tony.
Old Oct 5, 2005 | 12:10 PM
  #38
I did check quotes on other companies and they are more. NJ insurance is insane, let alone when you have points on your liscence. I'm sure that hobie would agree with you (he's in Jersey too).
Try www.esurance.com they should be very reasonable my insurance went from $432 a month down to about $252 a month. They saved me a lot of money.
Old Oct 5, 2005 | 12:52 PM
  #39
gregivq's Avatar
For NT Lancer or EVO?
Old Oct 5, 2005 | 01:08 PM
  #40
HobieKopek's Avatar
He drives the CNFX turbo Lancer. It's an ES.
Old Oct 5, 2005 | 01:18 PM
  #41
thanks for the info on CNFX and the insurance...ill have to look into the insurance soon...im going to see how this ACT stage II holds up with FI and then decide if i want to upgrade again.
Old Oct 5, 2005 | 01:27 PM
  #42
If you want to stop down anytime let me know im always down I can show ya my car. Just to get an idea of what kind of work cnfx does. If not anytime in the near future you can also check out the thread on my turbo es. https://www.evolutionm.net/forums/sh...d.php?t=148107
Old Oct 5, 2005 | 03:17 PM
  #43
Lil red '03's Avatar
Ouch - sorry about your clutch. I know the feeling of being kicked in the *** repeatedly. For info on the works stuff PM wiretap - he has the works flywheel/stage 2 clutch/ ss clutch line package and he really liked it. I was going to go that route too but I am getting transferred in November so i needed to save the money for moving
Old Oct 5, 2005 | 03:18 PM
  #44
oh yeah - thanks for that site comatose
duhhh
Old Oct 6, 2005 | 11:02 AM
  #45
WADADLIG_OZ's Avatar
Hobie did you buy a new TOB or just reuse the old one? I know your car was down for a long while.
WADAD
