Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
tranny....NEED HELP ASAP!
Old Nov 22, 2005 | 12:32 PM
HBZ's Avatar
HBZ
this is probably a stupid comment but did you bleed the air out of the system at the TOB ..
Old Nov 22, 2005 | 08:01 PM
Lancerguy'03's Avatar
well its not an external issue....i took it to a shop that knows there Trannys.....they said its most likey not the gears....but the clutch/pressure plate or thorwout bearing....i rule out the clutch and pressure plate becuse....the pedal feels the same...clutch MIGHT be out...but it only has 15000 miles on so i dont think it is that....never launch the car or anything that bad....so i and my friend think its the throwout bearing because it has been rattling for sometime....the shop thinks it might have got stuck in/to the pressure plate....and plus i remember reading that Mits. has relesded a better version of the TOB. so hopefully that is whats wrong....they goin to call tommorw and ill post what up what they say......THNX for the help
Old Nov 22, 2005 | 08:15 PM
EVO-JOE's Avatar
Try A Clutch Pedal Freeplay Adjustment. Ther Is A How To On This Site. Try Getting In Touch With Shepard Racing For Some Advice. The Know Their Ship.
Old Nov 23, 2005 | 08:46 AM
ok the shop called and they said its just the clutch....just the spings on the clutch....with to me kinda sounds like a manufacter ****up....cause its an ACT Stage2....that souldt happen at 15000miles...let me know what u guys think..
Old Nov 23, 2005 | 11:28 AM
found out more about the clutch......the springs are shot and the metal part in the center of the clutch is CRACKED!!!! the acutal contact material is perfect....the shop said i still have LOTS of miles on it....PISSSSSED!!!!! im goin to call ACT..
Old Nov 23, 2005 | 11:39 AM
rhyzin's Avatar
wtf???
well good luck with it. something new happens every day.
Old Dec 29, 2005 | 02:09 PM
Earl Needham's Avatar
Veteran: Air ForceVeteran: Marine Corp
Is the clutch a hydraulic unit? If so, it's pretty common for this to occur when the clutch fluid is low. Looks just like a brake fluid resorvoir, but it's near the cluth pedal inside the engine compartment.
Earl
Old Jan 21, 2006 | 10:22 PM
comatose721's Avatar
bumping this to find an update.
what's the word with the clutch. i'm on my 2nd ACT stage II clutch. again the disc is fine. i bent the fingers on the PP, almost ground a hole in them with the TOB, snapped off the bottom coil on a spring, chipped the others.....yeah a lot of abuse. if you still have the clutch on your hands i would really be interested in pics.
mine didn't blow out from hard launches...they said i shift too quick, hard, and 'chirp too many gears'....yeah. if you did the install yourself (like i did) ACT will wash their hands of you. (unless you are a certified shop) IT IS VERY LIKELY that you did not torque the assembly onto the flywheel properly. after a couple of harder days on the car the pressure plate starts to "potato chip."
picture the clutch disc in it's normal position. now take a little bit out of the springs, bend those fingers a bit, and a put a couple hot spots on your flywheel. when you go to engage/disengage the clutch only part of the disc will back off the fly. thus the car will 'stay in gear.'
Old Jan 22, 2006 | 08:38 PM
ahh...yeah i still have the clutch....just need a camera....ill work on putting it up sometime this week. thnx for the info.
Old Jan 22, 2006 | 09:54 PM
awesome. i am interested in the pic's. i'll post mine when i get around to it. i burried that thing somewhere in my garage when i got aggrivated with it.
...and i am always willing to share info anywhere that i can. you're welcome
