Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
auto/manual final drive compatiable?
Old Dec 19, 2006 | 11:04 PM
bagice's Avatar
Question auto/manual final drive compatiable?
I looked up the specs on the final drive gear ratio on the auto vs manual. The auto was 4.04ish and the manual was 3.62ish (can't reamber exactily). I was wondering if any one knew if I could swap the auto final drive into the manual. I have spare of both trannies but if there not compatiable I would like to sell the auto untouched. The lower gear ratio would make me happier! Thanks in advance for the knowlage not the guess's.
Old Feb 1, 2007 | 12:51 PM
bagice's Avatar
to avoid sounding like a noob I found my paper with the gear ratios. The final drive for the manual is 3.722 and for the auto it is 4.041. If anyone knows where I could find an exploded diagram for the two transmissions that would be vary helpful.
Old Feb 1, 2007 | 01:27 PM
SLVROZ_03's Avatar
Good, question... But it'd be hard to believe the gears would interchangeable. But props for even thinking about it ! We do this all the time on turbo'd Honda trannys, so why not the Lancers?
Old Feb 2, 2007 | 08:44 AM
Blacksheepdj's Avatar
HIGHLY doubt it. The gears all work together, so I can't imagine that you could slap one in and expect it to work.
Old Feb 4, 2007 | 12:14 PM
otter's Avatar
EvoM Administrator
I think you'd have better luck getting a hold of the final drive gear out of a Ralliart; it's more likely to be interchangeable, and that'll get you a 4.05 ratio.
Old Feb 5, 2007 | 08:59 PM
bagice's Avatar
Is that the final drive ratio for the auto or the man. Thanks for pointing that out, I forgot about the Ralliart. My problem is that i allready have a spear auto from a lancer LS. I traded some for work a spare motor and the trannie came with it.
