Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
do i NEED a pressure plate?
Old Jun 5, 2003 | 02:45 AM
rhyzin's Avatar
i'm starting to experience slow engagement into second when i shift at 5500 from first. i have a manual and am thinking of getting a new clutch. do i need a new pressure plate when upgrading my clutch? i was thinking of getting the road race one. the disk itself is pretty cheap but the pressure plate is damn expensive. so do i need the pressure plate?
Old Jun 5, 2003 | 02:53 AM
Juiced02 Lancer's Avatar
clutch
well id say if ur gonna get the disc go for the matching pressure plate. I would not mix a highperformance disc and a stock pressure plate sounds like troubble , plus i dont think it would feel right haveing just half of it done right
Old Jun 5, 2003 | 03:05 AM
jbrennen's Avatar
Replace the pressure plate. You're going to be spending a lot of time (if you do it yourself) or money (if you pay for the labor) to replace the clutch disc. There is no extra work to replace the pressure plate, since you need to remove it to get at the disc anyway.
If you're upgrading the clutch, the pressure plate upgrade is just as important as the disc replacement. Also, there could be fitment issues if you try upgrading the disc only -- you don't want to find out in the middle of the job that your new disc won't work with your old pressure plate.
Old Jun 5, 2003 | 03:14 AM
HobieKopek's Avatar
You may as well do both at once. The 22nd or 23rd I can confirm fitment of my clutch...maybe earlier if I'm lucky.
EDIT: A 1.8l Mirage clutch if you didn't see it already. Pretty much just making absolutely absolute that it'll work, though I have little doubt to begin with.
Old Jun 5, 2003 | 04:02 AM
rhyzin's Avatar
thanks guys!
good luck hobie with that install, not that you'll need it.
Old Jun 5, 2003 | 04:06 AM
HobieKopek's Avatar
Nah, I'm not even doing it. I'm going to try to spend the day down at ILP and chill for a bit. Hopefully my Wilwoods will be in by then and I can put them on while I'm there. If not I'll either heat wrap my manifold or work on my gauges while they work on the clutch. I'm leaving the car there for the weekend regardless though so I may not have confirmation on the clutch until as late as Monday the 23rd.
armysoldier1073
Sep 7, 2011 05:53 AM
Illrunya
Apr 7, 2011 01:03 AM
krazykorean84
Feb 25, 2011 11:25 AM
mrbkkt1
19
Mar 18, 2010 03:41 AM
Kerr
Dec 15, 2005 07:36 PM
