Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
new clutch
Old Jan 22, 2008 | 10:38 AM
iamme9182's Avatar
new clutch
i am really unfamiliar with the drivetrain stuff so please forgive anything stupid i say. My clutch stopped working the other day, the pedal started going straight to the floor without any pressure. I got it to a shop, they pulled everything apart and said that a bearing went out in the slave cylinder and destroyed the clutch. they are quoting me a price of 1500$ to get it replaced with only 550$ of that being labor. here is the breakdown from what i understand:
clutch 141$
pressure place 210$
slave cylinder 234$
some kind of bearing 160$
mill flywheel 125$
The price seems way out there to me, do these #s look like they are in the right ballpark for this? If not, if i were to have them put in an aftermarket clutch which one should i look at for a completly stock car that is just a daily driver?
I am moving across the country in 2 weeks and really cant afford that much. Please help!
thanks
Old Jan 22, 2008 | 12:29 PM
SLVROZ_03's Avatar
Well, will you need to this car to be operational for the move? or will it be trailered? If not needed, then wait till moved.
Somehow I doubt the slave cyl is bad. The milling costs are outrageous. The "some kind of bearing" is the Throw Out Bearing (TOB) that comes with the clutch/pressure plate pkg! Basically they're trying to rape you!
If you order a Works clutch, it'll come with the clutch, pp, tob, and the alignment tool for like $400 I think. I do suggest milling the FW, but that price needs dropped like a bad habit!
Sorry about the situation, but tell them how it's going down and don't back down. Tell them you'll go somewhere else!
Old Jan 31, 2008 | 04:01 AM
jmaloy1701's Avatar
them people are ripoffs
i got the same quote so i said bite me and went online to ACT and bought a hevy duty racing clutch and pressure plate for 400 then went to the dealer and got the TOB for like 115. im bout to put it in myself here in a couple hours lol. the stock clutches are more expensive than the racing clutches lol hope this helps
Old Jan 31, 2008 | 05:22 AM
Kurt's Avatar
When I did my clutch 2 years ago, I paid $500 for a clutch/pressure plate/ TOB and another $300 for a lightweight flywheel. I forgot what the labor charges were. What are they telling you that are going to charge for labor? It sounds like you are getting ripped off.
Old Jan 31, 2008 | 08:51 AM
ILovE WHEELS's Avatar
ur pedal going straight to the floor sounds like your slave cylinder went out. my pedal did the same thing about 4 months ago.
as far as parts go i think i paid 3-400 for oem clutch n pressure plate, and slave cylnder but i found a cheap tuner shop to do the labor which was like 350
Old Jan 31, 2008 | 05:35 PM
OBXlancer's Avatar
Just had to replace my slave cylinder and it was like $140 from dealer. Thats prob the pedal to floor problem. As far as the throwout bearing it comes with the clutch kit usually. I got a stage 2 Spec Clutch kit and the throwout bearing was w/it. That was a lil less than $400. Thats only $540
