Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
ralliart tranny onto oz or es engine
Old Jan 18, 2009 | 12:19 PM
turbotime's Avatar
anyone know if it has the same bolt pattern to bolt onto the oz or es engines?
thanks.
Old Jan 18, 2009 | 12:54 PM
ambystom01's Avatar
Don't think so.
Old Jan 18, 2009 | 01:07 PM
Jehuty's Avatar
No it doesn't.
Old Jan 18, 2009 | 04:53 PM
Juan Martinez's Avatar
I've heard its basicly the same transmission only with a different bellhousing and gears. It may work if you use your 4g94 bellhousing. You may have to use ralliart axles.
Old Jan 18, 2009 | 05:58 PM
Jehuty's Avatar
I'm trying to find out if a 98 1.8 liter mirage tranny fits, and then if i do that if i can still do everything the same on the G64 swap.
Old Jan 18, 2009 | 06:01 PM
turbotime's Avatar
Thanks for the info guys, I found it strange the dealer doesn't have different part numbers for them.
Old Jan 18, 2009 | 06:36 PM
As far as I know, the transmission is the same, just different gearing. You may not have to go as far on the g64 swap as the other guy did. You might, and should, just be able to use 4g69 axles and not open up the transmission and change out the gears.
Old Jan 20, 2009 | 06:07 AM
Jehuty's Avatar
I don't mind the opening up process because I know transmission people who can do that. I just...want to know if the mirage will work. Now when you say "different gearing" what do you mean? Different RPM bands? Or you mean just the gears on the inside are different?
Old Jan 20, 2009 | 09:46 AM
The gearing is different, I guess that means rpm bands.
Old Jan 20, 2009 | 10:33 AM
4g94T's Avatar
I believe the ralliart has the same gear ratio as the EVO VIII
Old Jan 21, 2009 | 05:05 AM
Jehuty's Avatar
I would recommend OP to go my route and check on the mirage tranny before looking at the ralliart tranny. Just my .02
Old Jan 21, 2009 | 08:07 PM
senate6268's Avatar
The 4G69 transmission uses an intermediate shaft whereas the 4G94 transmission does not. Only the driver side axle will work.
wesleylawson6
Lancer Engine Tech
Mar 30, 2016 08:02 PM
j0hnjay
Jan 15, 2015 07:59 PM
wesleylawson6
14
Jan 6, 2015 04:28 PM
yukyucky
Aug 29, 2009 10:25 PM
Evopwr
Canadian Forum
Dec 1, 2006 06:04 AM
