Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Automatic Transmission Filter
Old Sep 1, 2009 | 05:52 PM
drifte's Avatar
Has anyone on here actually changed the transmission filter on their auto lancer? Im working on an 03 OZ and have flushed the system. Now I took the trans pan off which is actually on the front and theirs no filter. The gasket that came with my filter matches the pan, but behind the pan is mechanical parts of the trans. Im going to look at it more and see just what Im supposed to do here, but I highly doubt I should take those parts off.
Any one with any actual experience doing this please share some insite. I have a long drive this weekend and want the car in good order.
Thanks,
-Colton
Old Sep 1, 2009 | 08:34 PM
Green_Bandit's Avatar
For our cars there is no replacable filter. There is a screen near the middle of the transmission but you wont get to that unless you take it apart.
So, short and sweet. No, there is no filter to be "replaced" during regular maitenence.
Old Sep 3, 2009 | 06:45 PM
drifte's Avatar
Thank you for that. I went ahead and returned the filter, and after the flush the car now slips into 3rd gear...Don't know whats going on their. Used appropriate fluid and volume. Hop it goes away I guess.
Old Sep 10, 2009 | 12:50 PM
TheTransporter's Avatar
car shouldnt slip after just changing the oil, regardless if you took th epan off or not. what type of trans oil did you use?
Old Sep 11, 2009 | 06:23 PM
drifte's Avatar
I used the directions someone posted on here about flushing the transmission. I even had the pan off so figured I'd for sure need the 5 quarts that were said to be put in. After 5 quarts in the car was about 1 quart or more over filled. So that was why it slipped, it was overfilled, I drained it out and eventually got it just right. Then had to reset (unplug the battery) to get the trans to shift correctly. These cars are funny like that, TCU seems to learn its way and keep it. Now its all good though. Took a lot of work getting the car to operating temp. Get it level and check fluid, drain some, check level etc. My garage is sloped..maybe thats the real problem.
chassuter
29
Sep 12, 2022 04:55 AM
Bryan Ashby
Mar 24, 2016 05:14 PM
Ta/Fc1383
Jun 14, 2015 04:37 PM
Roen
Mitsubishi TC-SST Discussion
Mar 19, 2014 08:29 PM
MISHI
Nov 23, 2011 09:20 PM
