Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Clanking noise from Engine
Old Apr 21, 2010 | 06:44 PM
  #31
Steven6208's Avatar
It happens after I turn on the car everytime and start hitting the gas in first gear.
Old Apr 21, 2010 | 08:10 PM
  #32
dustyp34's Avatar
yea man check your sway bar end links and see if that helps
Old Apr 21, 2010 | 08:20 PM
  #33
MidMex's Avatar
This is just crazy. I haven't done anything for my car but the damn dealership wants me to go in during the week and see if it does it then. I'm really going to try and get my car in soon. When I do I will keep you guys informed.
Old Apr 21, 2010 | 09:38 PM
  #34
yitzac1990's Avatar
just now read through this thread....
please do keep us informed, im having the same problems with my car too! whenever I back out of my driveway, there is a loud clunk, but that is about the only time. then and sometimes when i start accelerating from a stop.
Old Apr 22, 2010 | 04:01 AM
  #35
kalpakiotis's Avatar
Originally Posted by dustyp34
mine is coming back tightening the sway bar end link helped but i havent beed to my fathers house to use the impact gun so i dont know if that is for sure the problem or not. does it only happen to you after your car has been sitting for a while and when you first turn your wheels it clunks or does it do it more.
you don't want to use an impact wrench on the end link, you will def strip out the hex socket in the internal screw. It happened to me when i was installing the megans, wound up having to put a new slot in it so that i could get a flat head screw driver in place.
Those nuts only need to be torqued to 20 ftlbs.
Old May 3, 2010 | 10:07 AM
  #36
CamShaft's Avatar
Go to mitsu, tell them your story. Get them to check under the car, susp. eng. mounts ect. They should do a full check to see if anything is loose or abnormal under warranty!
Old May 4, 2010 | 09:49 AM
  #37
MidMex's Avatar
I went to the dealership and they should do something but that damn place didn't do jack. They drove it and just like my luck nothing happened so they parked the car and said nothing was wrong.
Old May 13, 2010 | 03:03 AM
  #38
Steven6208's Avatar
I went to go talk to someone, and they were too lazy to do their damn job. Said from what I described, it didnt sound normal, but they didn't have enough bodies to check it out... even though there was no one there and about 4 people sitting around...
Old May 26, 2010 | 04:48 AM
  #39
MidMex's Avatar
Oh man that is messed up.
Old May 26, 2010 | 05:03 PM
  #40
dustyp34's Avatar
yea well i found the problem with my sway bar end links today and here it is.
Today I finally had the time to go yank the passenger side front wheel off and check that link since I didnt do it the first time. Well when I got the wheel off and looked at it something didnt look right and what that was is the end link is bent at the bottom.
I got to thinking what the hell could I have done to bend the damn thing. I pondered for a min and then I realized what caused it. What happened was I had to have a lug nut broke off around october or november something like that. The way they did it was they took a long a** crow bar like thing and wedged it in between the wheel and the strut and while one dude was hitting it with an impact wrench the other person was yanking on the crow bar thing and in turn bent the damn end link. How do i know this is what caused it is because if you look at where it is bent at you can see the notches that was made my the crow bar.
Now I got to get another end link so I can replace the bent one. Damn stupid a** people
Old May 30, 2010 | 01:45 PM
  #41
MidMex's Avatar
Thats pretty messed up but I'm pretty sure that everyone else that has the same problem didn't have a broken lug nut. Not trying to take anything away from you and I'm happy that you found the problem and is able to fix. I hope that when you are able to get it fixed that your problems are gone. I'm pissed that the dealership didn't help me more. Keep us updated. Thanks.
Old May 30, 2010 | 10:13 PM
  #42
dustyp34's Avatar
yea i know i hope that it is in fact the problem. I have went to the dealership a couple of times for noises coming from the car only to have them tell me that it is normal, when i know that it wasnt doing that when i got it.
Old May 30, 2010 | 10:20 PM
  #43
yitzac1990's Avatar
mind taking pics of your endlinks? i tried tightening mine, all 4 bolts, but they were tight enough to wear they wouldnt even budge with a ratchet....just want to see how bent yours are and see if I in fact need to replace mine too
Old May 31, 2010 | 10:38 AM
  #44
dustyp34's Avatar
will do when i get a chance. ill try to get those within the next coulpe of days.
but i will give you a verbal description for now. if you take your front tire off and locate the end link mine is bent at the bottom where it connects to the sway bar.
Old Jun 9, 2010 | 01:53 PM
  #45
dustyp34's Avatar
sorry bout the quality i took it with my mp3 player and it was bright as hell outside.
