Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Is Resistance when Shifting into First Normal?
Old Dec 3, 2003 | 04:32 PM
pgmike's Avatar
ive had my lancer for maybe 3 months and the first month i had it i would downshift to first going anywhere below 20mph, then all of a sudden it started grinding when ever i tried doing that and i never do it now. i just wait till im stopped to put it in forst. usually i dont even use first, instead i start it in 2nd bc i heard that it increases gas mileage. is that true and is what im doing hurting my car at all?
Old Dec 3, 2003 | 09:34 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Leaving it in second is indeed good for gas mileage, and easier on your trans. For normal driving, you really should only use second when going from a stop or almost stopped. You're on the right track by everything I know.
Old Dec 4, 2003 | 03:51 AM
JVlancer's Avatar
2nd gear = super bogg, what it your on in incline???
Old Dec 6, 2003 | 12:43 AM
Moderator
Bomb Squad Unit #02
if you're going like 5 mph on an incline, go ahead and shift gently into 1st. Otherwise, anything above 5 mph won't bog all that much. Or you could just come to almost a stop so that you can shift into 1st again. But otherwise you're faced with the choice: bog a little or hurt your tranny a lot.
Old Dec 8, 2003 | 05:13 AM
JVlancer's Avatar
id rather hurt my tranny than stall
Old Dec 8, 2003 | 05:28 AM
liquidlancer's Avatar
i never have a problems shifting into first at any speed
and if i remebr corectly 1st gear is syncrod
but that just from ym exxsperiences ripping trannys apart
Old Dec 8, 2003 | 06:46 AM
JVlancer's Avatar
liq.. where u live dude?
Old Dec 8, 2003 | 12:28 PM
HobieKopek's Avatar
I can't find where I read the non-synchro'd first gear thing, but if first is synchro'd I can't see why it would be so difficult to downshift into it. Joe, if you've seen a first gear synchro though then you'd know better than the rest of us. We could always check with the 5g Mirage crew. Same tranny anyway.
Old Dec 10, 2003 | 01:43 AM
Moderator
Bomb Squad Unit #02
But if it's syncro'd, why would it not let us shift into 1st until we either go down to 10 mph or rev match?
Old Dec 12, 2003 | 06:45 PM
lanceryellow's Avatar
i'm pretty sure first gear dosn't have the syncro mesh and neither does reverse its that way in alot of cars
Old Dec 12, 2003 | 10:44 PM
fkrzo's Avatar
Pgmike, taking off in second is gonna kill your clutch. Do you look for performance or economy? Lugging a motor is just as bad, if not worse than revving it out.
Old Dec 13, 2003 | 09:03 AM
pgmike's Avatar
economy, except when some civic or jetta challenges. thanks for the info. i wont be starting in secong anymore. its annoying anyway starting out in a crawl.
Old Dec 14, 2003 | 09:32 PM
Moderator
Bomb Squad Unit #02
I believe the cars that launch in 2nd are the high torque ones that can not get traction in 1st... such as big block V8s and extremely modded Evos, etc.
Old Dec 15, 2003 | 11:07 AM
HobieKopek's Avatar
Correctamundo. The purpose of bypassing first is only to prevent unending wheel spin.
Old Jan 1, 2004 | 12:41 PM
cdyancey's Avatar
Thumbs down
wow what insight............ lets cause damage to an expensive item but lets not stall my car out........... WTF are you smoking?
that makes absolutely ZERO sense............
evoforstevo
Jul 21, 2017 05:07 PM
AllDayAnthony
Jul 3, 2017 06:49 AM
Sustain
Dec 29, 2016 07:44 PM
zakdamunky
43
Jul 31, 2013 09:26 AM
keevo54
12
Mar 19, 2011 10:46 AM
