Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
clutch replacement
Old Apr 30, 2011 | 11:18 PM
hiramabif's Avatar
clutch replacement
Does anybody changed their clutch on their lancer? what brand and stage? do we still need to change the flywheel as well?
Old May 2, 2011 | 05:51 AM
yitzac1990's Avatar
what motor/transmission do you have?
Old May 2, 2011 | 07:30 AM
hiramabif's Avatar
I have a 4b11... is there any aftermarket flywheel for this type of engine??? tia
Old May 2, 2011 | 09:32 AM
yitzac1990's Avatar
ACT MR1-HDG6 is a great clutch, it was in my car when I had it. as far as a flywheel, im not sure. you could try an EVO X flywheel, but not too sure.
Old May 2, 2011 | 09:00 PM
hiramabif's Avatar
thanks for the suggestion bro... but with that kind of clutch, is there any kind of modification or adjustment needed for the flywheel? is your flywheel still stock?
Old May 3, 2011 | 04:22 AM
yitzac1990's Avatar
yep, i was on the stock flywheel. when it was installed, the shop got the flywheel turned a little to smoothe it out.
Old Jun 27, 2011 | 02:37 PM
sam8989's Avatar
if u drive ur car propertly ur clutch should last u forever
Old Jun 28, 2011 | 12:15 AM
hiramabif's Avatar
you are right sam8989, but that is when your car is intended for daily drive...
Old Jul 20, 2015 | 09:37 PM
kindaloweredlif's Avatar
If you go super cheap it is a nightmare. Im already 2 months down and I think it's because of dirt cheap parts.
Ralli_Red
Apr 7, 2020 12:35 PM
pistons4550
Mar 2, 2016 06:26 PM
captinnitro
Feb 24, 2016 10:03 AM
Jhusey
Dec 24, 2015 05:11 PM
kanovic
Dec 13, 2015 01:19 PM
