Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
cvt-sst
Old Aug 22, 2011 | 07:25 PM
a.w.o.l's Avatar
Post cvt-sst
guys do u'll think the sst tranny will work if i replaced my cvt tranny wit it....?
Old Aug 23, 2011 | 09:07 AM
CamShaft's Avatar
no
Old Aug 23, 2011 | 09:51 AM
evo_soul's Avatar
NO. It will not mate to the regular lancer motor
Yes if you put an EVO or Ralliart Engine & Turbo. But lots of work
Old Aug 24, 2011 | 09:17 AM
a.w.o.l's Avatar
Ok thanks for the info, just wanted to know if it could be an optional upgrade if somting ever happened to the cvt tranny...
Another Question----how safe is it to burn out wit a cvt tranny...
Old Aug 24, 2011 | 11:04 AM
evo_soul's Avatar
Not very safe. The CVT is a very reliable transmission. More reliable than a regular Automatic transmission. However, The CVT design doesnt handle heat very well. So if you in an already hot climate you must make sure you run a better CVT fluid. Because if your driving it hard or aggressive.
Getting to your immediate question. Mitsubishi goes out of their way to tell you "DO NOT TOW" with your car. The cvt's TQ converter doesnt handle towing conditions because of its lock up / engagement. Burn outs are going to be the same. Dropping it into gear from neutral will not be good, not holding the brakes and gas at the same time. Its not good for the cvt at all.
I would recommend against it. Sorry
Old Aug 25, 2011 | 04:26 PM
a.w.o.l's Avatar
thanks for all your feed back evo_soul..
do u think it'll be wise to put a cooler on the water line that goes into the tranny..?
Old Aug 30, 2011 | 04:07 PM
ninjacoco's Avatar
Balls of Steel
I tried to get mine to do a burnout once. The CVT must've recognized that I had the brakes on because it wouldn't rev past 2000 RPM no matter what I did.
nybluelancer
Apr 27, 2017 06:55 AM
cangri1788
Apr 21, 2017 11:33 PM
Welcome2GoodBur
Mar 20, 2016 04:59 PM
ultimateshoot
Feb 18, 2014 08:55 AM
Mitsu008
46
Nov 3, 2008 12:33 PM
