Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Clutch Slipping Questions
Old Oct 23, 2011 | 01:11 PM
campbmic's Avatar
I have an 02 OZ Rally and the clutch has begun to slip. I'd like to replace it myself, but have never worked on transmissions and had a few questions. What parts will I need to buy? After searching I've heard people talk about clutch slave cylinders, fly wheels, and the clutch itself.
Also, does anyone know a link to a walk through on doing this? Or a shop manual? I found one for an evo but I don't know if it would be the same on an OZ.
Thanks
Old Oct 23, 2011 | 04:50 PM
lil' jeff's Avatar
thats a very big job..you have to pull the tranny out the side of the car or both motor and tranny from the top. if you have the money then replace all those you listed minus flywheel unless its scared up. just get the whole clutch kit, you and a buddy can have it done in a weekend.
Old Oct 23, 2011 | 07:31 PM
03lances's Avatar
https://www.evolutionm.net/forums/la...able-here.html
easy to find searching
Old Oct 23, 2011 | 08:12 PM
drb's Avatar
drb
The flywheel can usually be resurfaced for about $50.00 at a local macine shop.
Dan (drb)
Old Oct 23, 2011 | 08:22 PM
CrAnSwIcK's Avatar
resurface flywheel, and clutch kit...that is all"throw out" bearing, or clutch release bearing, and grease should be included.
don't **** around with the other ****, unless your flywheel is warped or cracked, and your clutch slave is pissing fluid, don't bother replacing them, if you're going OEM.
you need:
a buddy
patience
good tools
jack stands
floor jack
penetrating oil
you might need:
the manual
stabilizer bar end links
differential oil seals
and try not to break anything...i broke a transmission bolt in half inside the block, took me a whole day to get it out and tapped.
Old Oct 23, 2011 | 08:49 PM
drb's Avatar
drb
you need:
a buddy
patience
good tools
jack stands
floor jack
penetrating oil
you might need:
the manual
I agree.
Old Oct 27, 2011 | 03:41 PM
campbmic's Avatar
Cool thanks guys, well Im going to get this package. Cheap, and since its a non turbo lancer I figure I dont need a super crazy expensive clutch kit
http://www.ebay.com/itm/NEW-HD-COMPL...ht_2667wt_1037
I do have some more questions though. For about twice as much I can get an EXEDY kit what do you guys think? Im pretty broke so I would rather go with the cheaper what do you guys think? Spend more for the EXEDY or no?
http://www.ebay.com/itm/2002-03-Lanc...ht_1670wt_1270
Also, how can I tell if I need a throw out bearing?
Thanks
Old Oct 27, 2011 | 06:12 PM
03lances's Avatar
If your in there you should replace it.
evo robert
Sep 2, 2015 09:29 AM
powrider411
Lancer Troubleshooting
May 19, 2012 02:15 PM
dafoe69
19
Aug 7, 2006 11:20 AM
vassago
13
Mar 16, 2006 04:39 PM
wags528
Sep 30, 2002 07:54 PM
