Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Loud Ticking....Just Noticed today
Old Jan 13, 2004 | 01:13 PM
Gas'd LanOZ's Avatar
While sitting at a long stop light earlier today, I stretched and pushed on the brake hard. I then noticed there was a ticking sound and I could feel the ticking vibration in the brake pedal. I definitely notice it more when the brake is excessively pushed down, but I still notice is when sitting at a stop light and the brake is lightly pushed down. I don't know what this problem is and I searched for any related topics and couldn't find any of this sort. Does anyone have ideas. Haven't changed the tranny fluid and i have 18 grand on the motor. Would that have anything to do with it????Any Ideas????
Old Jan 13, 2004 | 01:21 PM
Sailorgoon's Avatar
Is it an auto or manual?
If auto, it could be the engine trying to pull away, meaning the brakes aren't engaged enough to hold the car at a stop.
This would be possible if the pads or rotors are badly worn or warped, and the engine is running cold, and idling high.
If it's a manual, I'm not really sure. Are you in gear while stopped, or do you put it in neutral and let off the clutch?
Old Jan 13, 2004 | 02:18 PM
nebolic's Avatar
all mitsubishi motors have ticking sounds, its the eletronic valve lifters, i think you're good, if anything just get them adjusted.
Old Jan 13, 2004 | 02:31 PM
i think i figured the problem out...mechanic here suggested my abs pump sucked in some air. that is what is causing that sound and the vibration in the pedal. however, it doesn't make the sound when the auto is set in neutral. so i don't know.
Old Jan 13, 2004 | 06:50 PM
please delete this thread..i got the problem solved
Old Jan 13, 2004 | 06:57 PM
bobaab's Avatar
mind telling us what it was?
Old Jan 13, 2004 | 06:59 PM
defeated26's Avatar
damn! i have that exact same problem... it feels or seems like something is loose. you have got to tell me what it is... it has been driving me insane!
thank you in advance.
Old Jan 13, 2004 | 07:05 PM
Iamkar33m's Avatar
OZ's have ABS? I thought all trims of lancers didnt come with ABS brakes...
Old Jan 13, 2004 | 08:02 PM
Higgity Hank's Avatar
OZ Lancers DO NOT have ABS... that isn't the problem.
Old Jan 13, 2004 | 08:03 PM
Iamkar33m's Avatar
He had an OZ and only LS's have ABS...
Old Jan 13, 2004 | 08:18 PM
well, i guess i still don't know what the problem is.....and i have no ideas. All I know now is that the noise is louder the harder i press down the brake pedal when it's in drive. but for some reason the noise is gone. i'll be driving again once i leave work here tonight, so if i hear it again...for sure i'll be posting the problem.
Ichigo0Soul
21
Mar 26, 2014 05:43 AM
crankIT
10
Aug 29, 2012 03:44 AM
kazevo10
Nov 21, 2011 10:19 PM
m3typer
Apr 5, 2011 11:35 PM
boostedwrx
May 22, 2006 04:22 PM
