2002 Lancer ES Transaxle removal help (with pics)
Now that I really look at it, it really doesnt look like a zerk fitting. Is that where I bleed the clutch? Also there are two notches on bottom of transmission and one on motor. By looking at mine it looks like they should line up but they don't and its hooked to the motor so I don't know how it would even line up..
ahh ok makes much more sense. Thin I just have one more thing man. Thanks for all of your help I really do appreciate it much.
I'm afraid that it isnt hooked up correctly going by that picture. It fit up there perfect lined up everywhere. Put the bolts and seen that and now I'm worried.. that shaft in there will line itself up right ? And those gaps hopefully there not supposed to match up ?
Probably be making new thread for this but ill try to start here. I installed new clutch put everything back together, except for one plug on the front..? No clue where it goes...? Anyways tried to start it.. get a loud click.. Just one. Tried to jump it, same thing. Took starter off, had my old lady tried to start it and it just whines a little?
Before it was off seemed like it was trying to start but couldn't turn the flywheel maybe?
Or the gears werent lined up right with the flywheel and it was hitting that when it slid out?
I did yank the black plug off the starter when taking old clutch out replaced it with cheap harbor freight connectors.
Any clue here? Is my starter just bad ? It was full of black dust i tried to blow it out with air.
ticaaal70
10
Sep 25, 2016 01:09 AM
EvoooB
34
Jan 6, 2016 05:53 AM
EvoooB
Northeast Region
Jan 3, 2016 05:37 AM
FS[South]: Evo 8 head, iac valve, etc
steven121
19
Jul 31, 2014 06:34 AM
