Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Tranny from a different vehicle
Old May 13, 2015 | 05:39 PM
jimbo74's Avatar
Veteran: Air Force
Need to find a tranny for my 03 Lancer ES 5spd
Having a really hard time finding one, seems they are rare
from what I have found out online, looks like it is the same tranny as the rally art, but the rally art has different gearing and is rated to handle more
I think my tranny is a F5M42
It also looks like it was used in 2002 for the Eclipse with a 2.4L engine
is this info corrct? should I look for m tranny using an Rally Art spec or a Eclipse tranny?
Old May 13, 2015 | 06:23 PM
CrAnSwIcK's Avatar
gearbox is the same, bell housing will be different (starter in a different spot), but you should be able to swap it over. also axles might have different splines, but don't quote me...F5M42 is also used for the 8g and 9g gallant, as well as the 4g eclipse, and they all have different gear ratios, depending on model and trim...swapping bell housings means splitting the case...here's a video I made to demonstrate what's involved: https://www.evolutionm.net/forums/la...-assembly.html
Old May 20, 2015 | 09:40 AM
jimbo74's Avatar
Veteran: Air Force
can I get away without having a press?
I do have wood blocks, large sockets, and a bunch of bottle jacks
Old May 20, 2015 | 12:15 PM
jakermeister's Avatar
You could also use a 04-06 es/oz lancer tranny. The only difference is the external slave which is better than the 02-03 transmissions. 02-03 have a internal slave.
Old May 21, 2015 | 11:40 PM
CrAnSwIcK's Avatar
did you watch my video? the only thing you would need a press for is replacing bearings and gears/synchros.
Old May 27, 2015 | 10:21 AM
jimbo74's Avatar
Veteran: Air Force
so the 04-06 is definitely a drop in deal? what about the bellhousing? also, you said its got an external slave, how would I address this?
trying to make whatever I do as cheap as possible, and as painless as possible as well
Old Jun 22, 2015 | 11:38 AM
jimbo74's Avatar
Veteran: Air Force
time to re-visit this, and learn as much as possible.... still not sure what I am going to do yet. Lancer sits in the driveway.
Old Jun 22, 2015 | 12:13 PM
CrAnSwIcK's Avatar
I just dropped my transmission again yesterday took, about 3 hours, and I have a turbo kit that has to be removed first...it's not that hard of a job...
for the previous question going with an 04-06 tranny and external slave is just a matter of getting a throwout bearing and slave for an 04-06...
Old Jun 22, 2015 | 12:15 PM
jimbo74's Avatar
Veteran: Air Force
I know it isn't that hard to do, it's just a matter of $ at this point... and we are still driving it....
would that mount on the outside then I am assuming? what about the hydraulic lines?
Old Jun 22, 2015 | 07:20 PM
CrAnSwIcK's Avatar
they're brake lines...the flex hose from the master cylinder should already be there, so if you need to run a new line, it should not be too bad, or you could go with an aftermarket full steel braided line...OR your stock lines might work, depending on whether it's a flared compression fitting, or a banjo fitting...
Old Jun 22, 2015 | 07:25 PM
CrAnSwIcK's Avatar
car-part.com lists a bunch of used transmissions in California for $600, you could maybe talk them down, to $500...
Old Jun 23, 2015 | 11:21 AM
jimbo74's Avatar
Veteran: Air Force
I actually started looking through the online search engines hen this all started. I did contact a lot of those companies directly. They have it listed on sites like that, but when you call them, they end up being a lot more, and they want like $400 for a core charge as well, and usually around $200 for shipping......
Still want to rebuild mine, just waiting on funds really. I don't know what it looks like inside, so that is another issue... There is a possibility there is some real damage, and also the possibility that these things are pretty resilient and it is fine.....
I want to know why they are different, just to learn.... I do have the FSM, so if you guys say I need to crack that sucker open, I will
looking @ another thread here... I have found that I would need this:
and
that is the arm, the bearing, and the slave
Old Jun 23, 2015 | 12:22 PM
CrAnSwIcK's Avatar
and
For a transmission with the "internal slave", you would only need this piece. it is the bearing, with the slave cylinder integrated...
For an external slave system, would need this, yes:
however, if the transmission doesn't come with it, you would also need;
this:
this:
this:
this:
and this:
along with the appropriate bell housing, if the one you have will not accept these parts...
Old Jun 23, 2015 | 12:27 PM
jimbo74's Avatar
Veteran: Air Force
ah ok, I thought that fork I posted didn't look right....
looks liek I posted the fork what what I already have, the 03
Old Feb 16, 2016 | 09:47 PM
jimbo74's Avatar
Veteran: Air Force
So..... still looking into this, can I run a transmission from an 05 lancer with the 2.4l?
