Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Clutch?
Old Jul 1, 2015 | 12:34 AM
freelancer141's Avatar
Clutch?
I'm having a issue with shifting in my 2003 oz rally it is hard to get into a gear after coasting in neutral also when I shift into a gear the car shakes/studders a bit but every thing is fine at high speeds do I need to just replace my clutch or could it be something more.
Old Jul 1, 2015 | 08:27 AM
jakermeister's Avatar
Typically if its giving you trouble shifting its your syncros but I would check the fluid first. It could be too low or too high and also give you problems.
Old Jul 2, 2015 | 08:05 AM
CrAnSwIcK's Avatar
the clutch may not be disengaging properly (dragging), if that is the case, you'll burn out your synchros in no time at all...then you're really in a world of hurt...depending on your mileage, you may want to change your transmission oil as well...
try bleeding the clutch release systems first...does it make any rattling or otherwise strange noises?
diamondblackix
15
Sep 1, 2016 05:18 AM
Vivid Racing
West Region
Feb 25, 2010 04:35 PM
05EvoVIII
29
Apr 20, 2008 12:46 PM
Gruppe-S
Jan 12, 2007 04:11 PM
Go_Lancer_Go
17
Jul 23, 2005 07:09 PM
