Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Manual transmission problems
Old Apr 13, 2016 | 03:25 PM
mitsubishilover's Avatar
My 2003 oz rally won't shift into 3rd or 4th gear. It will go into the spot for 3rd and 4th but acts like it is in neutral but it takes off in 3rd or 4th gear most times just fine so I'm wondering what might be wrong and if it can be fixed
Old Apr 14, 2016 | 04:43 AM
CrAnSwIcK's Avatar
Most likely your 3rd/4th shift fork is worn out, so it's not sliding the sleeve far enough to engage the gears. You need to disassemble the transmission to resolve the issue.
Old Apr 14, 2016 | 07:35 AM
Wouldn't 3rd and 4th be gone completely if the shift fork was bad?
Old Apr 14, 2016 | 01:53 PM
jimbo74's Avatar
Veteran: Air Force
no, because 4th is where the engine is @ a 1:1 reduction to the gearbox..... the shift fork doesn't have to be off much for it to not shift properly..
this isn't going to be a simple fix, you are going to need a rebuild at the least....
seankhan
49
Nov 26, 2019 01:43 AM
AWDTFTW
Jan 25, 2015 11:51 AM
