Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Kartboy shifter linkage bushings install
Old Aug 16, 2004 | 02:45 PM
  #31
Blacksheepdj's Avatar
Package #1 is the ones this install writeup is for. There is one small bushing you replace with the two small pieces, and a big bushing you replace with the two big pieces.
Package #2 are the ones that go in the shifter base inside the console. For those, just take off the console and you'll see the 4 bushings at each corner of the shifter bracket. Take one out, replace it, repeat.
Old Aug 19, 2004 | 02:07 PM
  #32
hectik's Avatar
thanx alot blacksheep =)
everything is clear now....
Old Aug 19, 2004 | 03:42 PM
  #33
PS - Package 2 probably will not fit. Last I heard (and when I put mine in), they had made them a touch too large, so you'll need to file them down to get them in.
I filed for a while and then just forced them in. So hopefully they're actually in correctly...
Old Aug 19, 2004 | 07:51 PM
  #34
lancermarin's Avatar
I just installed mine today. They fit very well. The larger pair for the shift linkage needed a little force going in and on the rod, but with no adverse effects that I can see. The smaller pair slipped right in.
And holy crap, what a difference!
Old Sep 4, 2004 | 10:56 PM
  #35
LancerOZ's Avatar
Hey, I just ordered the Kartboy shifter linkage bushings (package 1).
If you want package 2, I would skip kartboy and go directly to RRM. They sold me a set of "Precision" brand bushings for my shifter-housing base. They fit perfect, with no filing needed.
I have the B&M + Precision bushings installed now.... as soon as I have the kartboy shifter linkage bushings in, I'll let you know how well the 3 work together.
Blacksheep: See the little copper/brass looking insert sleeve in the center of the stock black bushings? Do you remove that and put it in the center of the new bushings? It's the tiny brass thing in the very center in this picture
- Jason
Old Sep 5, 2004 | 12:56 PM
  #36
I didn't. There wasn't much play between the new bushings and the gearbox.
Old Sep 5, 2004 | 01:17 PM
  #37
pgmike's Avatar
Originally Posted by ambystom01
On the website http://www.kartboy.com/products.html there are only bushings for the evo. Are these the same as the ones for the lancer? Also is the shift knob threaded the same for the evo and the lancer?
late answer but yes they have the same threading. the OZ knob does have its threads deeper in the knob tho, the evo knob is smaller but it fits over the stock oz shifter.
Old Sep 5, 2004 | 01:44 PM
  #38
ambystom01's Avatar
Yeah i know that now. I got myself the shifter bushings and the shifter knob, definitely a worthwhile purchase.
Old Sep 8, 2004 | 02:43 PM
  #39
Dang, I need to check this thread more often! EDIT - OK, I subscribed to it!
No, leave the copper thing out.
Mike is right about the knobs - I've had all three (and then some!).
Old Sep 16, 2004 | 06:59 PM
  #40
LancerOZ's Avatar
I just installed this mod..... what a great little inexpensive mod.
I didn't think these bushings would feel much different, but they do. The lack of "squishyness" in the new bushings means the shifts are more solid and a tad bit quicker.
Basically, instead of moving your shifter lever, and having the stock bushings "squish" before moving the transmission linkage.... the new bushings are almost solid and don't "squish" under pressure. Instead, since they're more solid, the linkage is moved without any delay or "squishyness".... it's actually very nice.
My current tranny setup is : 1) B&M short shifter 2) Precision shifter-base bushings 3) Kartboy shifter-linkage bushings 4) a generic ball-style shift knob ....... I would recommend this setup to anyone, evo/oz/es/whatever... it makes a world of difference with everything changed.
- Jason
P.S. Blacksheepdj: Thanks a lot for posting this how-to. Your pictures, posts, and followups have been a big help. You turned a 20 minute install into a 2 minute install, gracias.
Old Sep 17, 2004 | 06:04 AM
  #41
Glad to hear it helped. Now enjoy!
and nominate me for guru!
Old Oct 20, 2004 | 04:09 PM
  #42
03OZLancer's Avatar
I got package 2 today even though I thought I ordered package 1. Well I installed it and it is well worth it. Although I they didn't fit well but I didn't shave down the bushing itself...I took a drill and a small drill bit and drilled the rim of the shifting mount itself. You could also use a dremill also but a drillbit works too. It took about an hour and is totally worth it.
Old Oct 20, 2004 | 04:30 PM
  #43
ambystom01's Avatar
Can you use the kartboy shift knob on the B&M short shifter?
Old Oct 24, 2004 | 12:04 PM
  #44
03OZLancer's Avatar
Yes the Kartboy shift knob will fit on the B&M short throw. It will fit because Kartboy used the same thread as the OEM Lancer shift lever and my stock shift knob fits on my B&M so that means the Kartboy has to fit on the short throw.
I just installed the under the hood bushings today and now I notice a werid noice when I shift certain gears. It sounds like rubber is rubing against something. I haven't really looked into it yet but I was just checking if someone else has heard this problem. It sounds like it is coming from the shifting consol itself...it could be one of the cables running to the tranny but I would have to check later.
Let me know if anyone else is having that problem.
Old Oct 24, 2004 | 03:25 PM
  #45
03OZLancer's Avatar
Okay I figured it out. Grease the crap out of your bushings before you put them in. Otherwise the will skeek like crazy.
