Weird noise when turning
When im going real slow like turning left in a parking lot theres this weird noise coming from the right side of the car, like a ticking noise with bolts lol, iono how else to describe it, any idea what it could be? it only happens going left and to the right side of the car
take it back to the dealership... sounds easily under warranty...
I have to go to the dealer b/c my steering makes almost a grinding noise when I have the wheel on the bumpstop when turned all left and moving forward... stupid mitsu cars!!
hey i got that same sound with my car. i took it to get checked out at the dealership and they said it was normal for lancers. i got my car with only 4 miles on it and its had that sound since i got. i only notice it when i'm going slow and turning into a parking space. just kinda annoying.
I was rear ended, so my car was in the shop for about a week. After that, for the next week or so, every time I turned sharp (like everyone else said, to go into a parking space, etc), it made a clunking sound. My 1991 Honda Accord did the same thing about 2 years ago, turned out it was the CV joints failing after the boots deteriorated. However, after about the week, the sound subsided. Who knows!?!?!?!
Weird noise plus
I have the same noise when the wheel is turned all the way,like a grinding sound.
Sounds like the rotors are hitting metal.
One other problem I have is a hissing noise coming from the power
steering rack.
T/S Guide says air in system. Fix by bleeding. Turn wheel all the way
to the right and left while using starter motor. Disabling Ignition system
so the car won'y start.
steering rack.
the grinding with the wheel turned all te way to the stops right or left is normal. it's like that on every car. it's to let you know you can't turn more and you shouldn't be turning te wheel this much. holding it against the bump stops like that can damage the powersteering pump.
Hissing Noise
Anyone have a hissing or ticking sound coming from the steering system?
When I hold the wheel and turn it a couple degrees the noise disappears.
When I let go of the wheel it starts. 2002 OZ
i have some grinding noise like metal rubbing aginst rough metal. but then again i think its because i installed the Tein Super streets. i think the pillow mount is rubbing on the top strut mount or the house of the chassis.
only put 3 thousand miles on it and already has problems
