rrm header tingling/rattling noise.
Old Sep 26, 2004 | 06:36 PM
hectik's Avatar
Angry rrm header tingling/rattling noise.
ok...i known about and hear this noise coming from my rrm header...its like a tingling/rattling kinda noise.....it does it when my rpm's are coming down... as of now..i got the header..and an rmr axel-back exhaust (it farts move than ever now)...i have the rrm test pipe sitting in my garage waiting for install, will the test pipe help it??? is it the header make this tinging noise??.....and thoughts on this??? any type of info would be great...thanks...
-hector
Old Sep 26, 2004 | 07:17 PM
Hotshot940's Avatar
i seem to have this problem with the header on my turbo set up, i think the problem is that it is rattling on the bracket to the belt on the left side of the engine if your looking under the hood, look down there and get someone to rev it and see if you can see anything that migh tbe touching.
Old Sep 26, 2004 | 07:37 PM
hectik's Avatar
ok coo...imma take a look at that tommorow....hopefully that is the problem...thanks....any other inputs?
Old Sep 26, 2004 | 08:17 PM
-=triggrhppy=-'s Avatar
you can actually rev the engine just by twisting the black plastic piece on your throttle body.
Old Sep 29, 2004 | 01:33 PM
livelyjay's Avatar
You'll want to check your heat shields as well, those tend to rattle a bit, and with mods and spirited driving can come loose. I'm going to pull mine completely off when I start installing my turbo kit.
Old Oct 14, 2004 | 01:28 AM
Delshay's Avatar
did you ever find out what the problem was hectik?
Old Oct 14, 2004 | 01:51 PM
hectik's Avatar
nope...still rattling.....i checked everything out and all looks good....i guess its just the sound the header makes..
sidewayzz
Lancer Troubleshooting
Jun 26, 2009 12:45 PM
Gr33dyMitsU
Lancer Engine Tech
10
Apr 20, 2007 09:27 AM
02lancerls
Lancer Engine Tech
27
Dec 11, 2005 10:08 AM
themassage2000
Jun 1, 2004 08:15 AM
Babblingsponge
Lancer Engine Tech
10
Dec 6, 2002 09:40 AM
