Need Help Please!!
Old Jul 14, 2005 | 07:10 PM
g0damy0uugly's Avatar
Need Help Please!!
okay.. i did a search.. tried a couple things... still cant figure it out......this is the situation..... i had a sound system (amp subs deck)... and it got stolen... i had ran all my wires under the panels and wen they jacked it.. i kept the wires.. i dont think any of the wires were producing any energy cuz it was hooked up to nothing... okay (im also amateur about cars/electronics.. stuff like that) so couple months later i notice my lights start to dim when i either press on the brakes or put my windows down, when i play music the light on the stock deck will fade as the bass hits, i turn on the a/c and i hear a pretty high pitched iono how to describe it but kinda like ticking. My car stalls sometimes when i turn my lights on at night (AND I HAVE AN AUTOMATIC)... and most of the time on hot summer days my a/c will not work and my remoteless entry wont either... but today out of all days im sick of it i dont know what the problem is... its 120 degrees outside mid day in vegas and im driving home from work and what happens 10 mins after i start driving.. THE AC DIES.. so i have no idea what the problem is but i need some help please someone.. HELP ME OUT.. ive never sweat so much in my life before
Old Jul 14, 2005 | 07:15 PM
mitsulancerrace's Avatar
i got the same issue as u except the stuff in bold, its just the battery not producing as much power anymore and ur amp is taking the power from the rest of ur stuff cuz there prolly isnt as much resistance. but that AC and stalling problem, i have no clue what thats from.
Old Jul 14, 2005 | 07:18 PM
Supa tek's Avatar
You have a power wire going to ground some where. Electrcity follows the path of least resistance, which is the wire touching ground. All of your elctricity is runnung through that wire anhd your alternator cant keep up. All of your accessories are dying because they arent recieving enough power. Trace all of the wires they yanked and see if there is a break in the wire or see if a power wire is in contact with metal anywhere around that area.
Old Jul 14, 2005 | 08:16 PM
oz4g94's Avatar
im not 100% sure but i think that may be a sign of the battery or alternator going out
Old Jul 14, 2005 | 09:28 PM
no actually my battery is brand new and my alternator is good actually..... like i said all my **** was stolen so......what should i look for?... i dont have any more of my sub amp wires running in my car now i just gota look for a wire break... most likely its in the deck or a/c area because that's where they ripped it but....any more input guys?
Old Jul 14, 2005 | 09:38 PM
Z_Lancer_Man's Avatar
Yeah, Id check the constant or 12 V supply to the deck and make sure thats not being grounded.
Old Jul 14, 2005 | 09:45 PM
twardnw's Avatar
go to a battery place, have them hook up an ammeter between your battery and car, turn everything OFF (but with the key on) and see if it's drawing any amps, should be very very minimal if things are normal, I don't know exactly how much tho. If it's high, then start pulling fuses on things until you find the fuse that has the draw, then find out what's hooked to that circuit
Old Jul 15, 2005 | 10:17 AM
hypo74's Avatar
Also, if you have a thumping system, may I recommend picking up a CAPACITOR. It stores energy, so when your bass hits, it don't drain the battery. Or you can also upgrade you alternator, to more ampage. But, then again check all your wiring as SUP A TEK stated.
Old Jul 15, 2005 | 11:31 AM
how much does a CAP cost? i think i need one too
Old Jul 15, 2005 | 11:46 AM
hypo74's Avatar
It all depends on the wattage that you are pushing. I am pusing abot 900 watts. I have a 1.5 farad capacitor. Anywhere between 90 and 130 for a good one.
Old Jul 15, 2005 | 12:05 PM
evokong's Avatar
the best thing to take sound system out .evething fine
Old Jul 15, 2005 | 03:50 PM
umm......its been taking out......cuz it was STOLEN... thats the whole thing man......i took out all the wires out of my car that was used with the system... my deck was stolen my subs and amp.....so i dont know what to do....is there anyone in vegas that is experienced in electronics that could help me out?!... please someone
Old Jul 15, 2005 | 06:11 PM
oz4g94's Avatar
why dont you have it diagnosed by an auto shop? just about every suggestion possible has been made, have some place check your alternator and battery and all other connections. you say you just bought the battery and the alternator is fine, but such products are very prone to being defective, so do yourself a favor and just go and have a shop check it out.
Old Jul 16, 2005 | 03:47 AM
yea no i have no a/c whatsoever...i hope its not thec ompressor....but im having an shop that specializes in electrical luk at it on friday....but man i gota wait a week with no a/c......I HATE VEGAS
LeXcite
Jan 17, 2022 08:05 PM
Tyrese Smith
Lancer Troubleshooting
Jun 20, 2017 10:20 PM
lghtngyello03
10
Jul 22, 2016 03:26 PM
BrandonIX
15
Jun 12, 2016 08:17 PM
1slowsti
Jul 25, 2015 04:13 PM
