Help ASAP-Very low idle
Old Jul 23, 2005 | 08:50 PM
davids2004's Avatar
So I went back out and regapped my sparkplugs today. So I finally removed the negative battery cable but was not able to unscrew it to remove it. So I just slid it back on. Im thiking my low idle now may have to do with the negative battery cable not making an extremely good connections. When I come to a stop my car goes all the way down to around 500 rpms and stays there and it sounds like the engine is having rouble staying running as it shakes a little. Any help here
Old Jul 23, 2005 | 09:21 PM
Sailorgoon's Avatar
Does the idle increase when you have the car in park (or neutral)? Are you running the AC?
Old Jul 23, 2005 | 09:22 PM
imapunkclaimer's Avatar
that happened to me when my plugs werent gapped to the right distance
Old Jul 23, 2005 | 09:26 PM
davids2004's Avatar
no it does not increase back when in park or neutral.
Sailorgoon's Avatar
Might have a bad plug or wire too. Nothing too uncommon. Remove all the plug boots and reseat them. Make sure there is no dirt or corrosion on the boot or plug.
You should go pick up a set of plugs at your dealer. They'll gap them for you if they aren't already the right range. I think I got my set of 4 for like 8 bucks. Best way to make sure it's not a plug issue.
Old Jul 23, 2005 | 09:31 PM
you can always just go to kragen and get a set of factory gapped plugs and you dont have to worry about it
Old Jul 24, 2005 | 12:39 AM
davids2004's Avatar
Well I increased the gap from .40-.41. And I also removed the battery cable. Last time I did it I removed the positive cable beacuse I can get it unscrewed and not have to slip it back on. Could it be a loose ground cable.
Old Jul 24, 2005 | 12:41 AM
davids2004's Avatar
I looked and they have no pregapped ones except at .44
Old Jul 24, 2005 | 04:39 AM
Slovak's Avatar
+1
I already told him something similar in his other similar spark plug post here on evom. Aftermarket plugs don't make one go faster, they just make your wallet lighter.
Old Jul 24, 2005 | 09:33 AM
davids2004's Avatar
IM not looking for speed just looking for something to make my car run correctly.
Old Jul 26, 2005 | 12:13 AM
chummer-x's Avatar
i just installed an rrm throttle body and now my car idle is about 1.5-2.0rmp any one have a clue????help
Old Jul 26, 2005 | 03:26 PM
chummer-x's Avatar
nevermind, bad sensor's
Old Aug 14, 2005 | 06:09 PM
davids2004's Avatar
bump.
GeoMitsu
Dec 27, 2015 02:41 AM
jake33
Mar 17, 2015 03:35 PM
DeFog
Sep 3, 2014 11:15 PM
03EVOGUY
Northwest Region
22
Aug 2, 2009 03:57 PM
Ralli04
Sep 6, 2008 10:03 PM
