engine is laggin
Old Mar 10, 2003 | 02:54 PM
lancer02Josh's Avatar
engine is laggin
ok so in about every gear maybe not 1st when i hit 2K RPM's my car feels like its puttin then returns 2 normal after 2k RPM's anybody know why this could be happening and my car is completely stock.
Old Mar 10, 2003 | 02:59 PM
Crzylizard's Avatar
Is the car all the way warmed up?
Plus...to top it off...2k isnt even in the powerband yet...if you have your pedal to the floor at 2K, then it could just be that its lacking air to mix with all the fuel
HobieKopek's Avatar
HITS 2k rpms? It's probably because you're driving in the sluggish part of the powerband. If you're shifting that low, chances are that's the cause itself. Driving under 2k is like pure economy driving. Don't expect any power out of the car that low in the revs.
EDIT: And if it's that low and you floor it, chances are you're just bogging the engine, forcing it to run entirely too rich.
Old Mar 10, 2003 | 03:03 PM
im not expecting power i mean it starts to put like im about to stall or somethin and my foot isnt to the floor
Old Mar 10, 2003 | 03:12 PM
Crzylizard's Avatar
I jsut think that you arent putting enouhgt mmmph into it. If youre shifting at 2k rpm...your lucky you arent stalling, and probably putting undo wear on your clutch
Old Mar 10, 2003 | 03:17 PM
HobieKopek's Avatar
I don't think wear would be an issue, but you're barely driving at 2k rpms...seriously. I mean, you're REALLY running close to stalling under 2k and if you floor it or give it too much gas you WILL bog it with the excess fuel.
Old Mar 10, 2003 | 03:18 PM
Crzylizard's Avatar
Im retarded...i was thinking something else when i mad the comment of the clutch wear
Old Mar 10, 2003 | 03:20 PM
well in 5th gear 50MPH is 2K RPMS should i shift later. so ur sayin im just shiftin too early
Old Mar 10, 2003 | 03:21 PM
wait so am i hurtin my clutch???
Old Mar 10, 2003 | 03:22 PM
HobieKopek's Avatar
Yes.
No.
The RPMs you SHIFT at and the RPMs your CRUISE at generally aren't the same things. If you don't plan on accellerating then driving low in the revs saves gas. If you need to go forward quickly then you're a fool to drive so low or not downshift first.
Old Mar 10, 2003 | 03:23 PM
Crzylizard's Avatar
Definitly.
Since day 1 i never shifted before 3K...that way when you get into your next gear... you should be above 2K...probably about 2300... I personally (in normal driving) shift at 3500.... you dont ge3t inot the powerband real good untill about 3300 or so...
long ans short of it : shift a bit later
Old Mar 10, 2003 | 03:26 PM
ok thanks it just started doin this thats y im askin now thanks
Old Mar 10, 2003 | 03:27 PM
Crzylizard's Avatar
Anytime
Thats what the forums are for
Old Mar 10, 2003 | 03:33 PM
stvbreal's Avatar
Originally posted by Crzylizard
Anytime
Loosk like to me you need to get that thing on the higway and open it up a bit. Clean the cobwebs out.
Old Mar 10, 2003 | 03:50 PM
purecoda's Avatar
Seriously. I don't ever shift below 3000 either, and most of the time its goes 1-2-5. (Its not speeding, its getting to 5 over the speedlimit as FAST as you FREAKING CAN!)
