i need help installing my apex-i SAFC!
Old Mar 21, 2003 | 10:56 PM
cincyracer2002's Avatar
i know some people on here have done this, if you could give me step by step instructions, or any help i would appreciate it!
Old Mar 23, 2003 | 07:05 PM
BuMpS's Avatar
I'm going try try and find my wirring diagram manual that came with my afc for you... It's going to be hard without u actually having the manual ... Now there is a website i believethrough Apexi that you can get the manual .. I know you said your comp is slow,but this is something you really should get.. Does one of your friends maybe have access to a faster comp or even a library? If I can I'll try and install my scanner and maybe even scan you the picture of the diagram.. i gottarun out fornow though,so try an see if you can get that diagram .. Run a search on here I believe theres a link to the site that has it.. aight man good luck..
Old Mar 23, 2003 | 08:48 PM
actually, my computer is very fast, i think someone else said that, im still tryin to get my hands on one.
Old Mar 23, 2003 | 09:44 PM
rhyzin's Avatar
http://www.apexi-usa.com/documentation.asp
Old Mar 23, 2003 | 10:58 PM
BuMpS's Avatar
There ya go, good looks Rhyzin help the man out . explain to him the importance of doing it at 4 in the morning though LOL...
Old Mar 25, 2003 | 11:04 AM
how do i get my damn glove box out the ***** wont move!
Old Mar 25, 2003 | 07:13 PM
BuMpS's Avatar
Cin theres a lil piece on the glove box kinda almost like a hitch it's on the leftside just push it forward from behind the glove box when you haveit open it should just pop forward (the latch that is).. then just go to the other side an apply force inward, and lower it down it should drop out once it's low enough then just remove that lil plastic piece below it...and your all set... Hope your install turns out better then mine, my S-AFC is givingme so much drama right now!!!
Old Mar 25, 2003 | 07:19 PM
BuMpS's Avatar
Really wish i had more space to work with ,for the wiring...guess maybe I should of takin the ECU out so I had more room to work with.. I dunno your kind of limited on wiring
therunningskier
Apr 14, 2020 09:50 AM
toverton30
Oct 1, 2009 11:18 PM
EViR
May 22, 2009 06:33 PM
jd888jd
Evo X How Tos / Installations
12
Mar 16, 2009 03:09 PM
importjake00
Driving Techniques
36
Sep 9, 2008 12:13 AM
