Activating 2-Step
Old May 21, 2009 | 12:03 PM
EViR's Avatar
Activating 2-Step
In ECU Flash their is a 2-step set at 2500rpm.
Now iv tried to get this 2step to work, but it doesnt?
Is their something i need to activate on ecu flash or what?
Clutch in, 1st gear rev.
Nothing... Gahh Help plz
Old May 21, 2009 | 12:11 PM
daymean's Avatar
have you switched to a different rom from your original? If so this may be the cause as someone else on here who has switched roms is not getting the stationary rev limit to work as well.
Maybe you should try raising the limit to a higher rpm .. maybe 4500rpm and try building up to that rpm slowly....
Old May 21, 2009 | 12:22 PM
fostytou's Avatar
EvoM Community Team
make sure the car has come to a complete stop for ~5 seconds before trying it. See if that helps.
What ROMid are you? Are you sure that it is at 2500 RPM and not 7500 RPM?
Old May 21, 2009 | 01:34 PM
EViR's Avatar
ROMid? How i find that out, its the one right out of my ecu, i havnt changed anything YET.
The Boost Enchancement (Anti-Lag) Start RPM: 2500
Old May 21, 2009 | 02:49 PM
fostytou's Avatar
EvoM Community Team
Boost enhancement has nothing to do with 2-step or launch control. Look for an item near the normal RPM limit.
Your ROMID is in the "info" section.
Old May 21, 2009 | 10:57 PM
EViR's Avatar
Where can i find this rpm limit thing? Iv never seen it in ecuflash..
Old May 22, 2009 | 12:01 AM
GotWheelHop's Avatar
It is called Stationary Rev Limit in the limits section. Stock on an of should be 7969rpm, which you will never see stock. Adjust the stationary rev limit to around 3500rpm to get used to playing with it, before you go crazy doing launches and burning up your clutch, or shredding your tcase.
Old May 22, 2009 | 06:33 PM
Cronic's Avatar
EVILR......... You need to read the "how to tune an evo" sticky. Its answers all the questions you are having...
Also there is a video on youtube if you type in ecuflash... That will cover up alot of your questions...
PhilJ
Sep 22, 2023 10:41 PM
PhilJ
Jun 29, 2017 08:31 AM
redboosted05
May 20, 2008 12:19 PM
SPOOLEDTSiAWD
Oct 15, 2007 10:24 PM
trboboost91
Oct 15, 2007 07:30 PM
