Help!
Old Dec 16, 2005 | 09:44 PM
drew02ES's Avatar
you're in tacoma? you should come help me and i'll pay you!
Old Dec 16, 2005 | 09:45 PM
Z_Lancer_Man's Avatar
If you can slide under the car, check the second O2 sensor as well. Its located right before the 2nd cat.
drew02ES's Avatar
were the hell is my ECU? i want to hook up my pb while i'm trying to get help with this other problem
Old Dec 16, 2005 | 09:46 PM
drew02ES's Avatar
i cant get under the car, no jack
Old Dec 17, 2005 | 05:41 AM
scorp64's Avatar
Ok, Drew, the silver metal piece covers the ECU, but thats not what you're looking for. Look at the bottom of that picture. See those black plastic tabs? That's the piece you're looking for. Just pull it straight forward.
Old Dec 17, 2005 | 06:11 AM
Well, we troubleshooted his electrical problems over AIM last night. Turns out it was a dead battery He ran his heater with the car not running for 30 minutes. After a jump start, problem solved.
Old Dec 17, 2005 | 09:43 AM
drucea's Avatar
good to hear its fixed. and if you havent gotten to your ecu still, look at the picture, the metal piece that has J0 on it covers the ecu, so you need to get to that exact spot but under the dash. so now look at the gold colored bolt and washer where your glove compartment was, stright down from that are the 2 black plastic clips, they are on the same cover that covers the ecu wires. pull it towards you and it should pop/slide off.
typer77
Jan 19, 2011 04:58 PM
switchblade906
Jan 1, 2009 11:55 PM
jojipoji
Dec 26, 2007 05:36 AM
pog0
Mar 4, 2007 07:31 PM
