CEL Still After Check Engine Light Eliminator
Old Jan 15, 2006 | 06:55 PM
Bigjoeski05's Avatar
OK i bought the Road Race Check Engine Light Eliminator installed it on the 2nd o2 sensor reset the ecu. Drove around for about 5 mins and bam the cel is on once again. My question is do i have a bad o2 sensor plus i have a Air Fuel Ratio Gauge and that thing goes crazy when i drive around back and fourth between all the levels and even when I'm at idle it will jump. I know the Guage is installed right because i have done about 10 air fuel gauges in the past year on friends cars. I'm taking the car tomorrow to get the code pulled.
Old Jan 15, 2006 | 06:58 PM
02lancerls's Avatar
I bought the same thing. I havnt installed it yet, but when i ran a computer test it said the problem was the 1st o2 sensor not the 2nd. Try installing it there and see if that helps
Old Jan 15, 2006 | 06:59 PM
Well i think i just have a bad first o2 sensor
Old Jan 15, 2006 | 07:01 PM
Because my a/f readings are crazy and just not normal i'm thinking the first 02 sensor is sending werid voltage to my gauge and plus i read if you have a bad front o2 sensor you get horriable gas mileage and for the past 2 or3 months i have noticed i have been at the pump alot more than i should be.
Old Jan 15, 2006 | 07:04 PM
ambystom01's Avatar
Do not install it on the first O2! If your CEL is because of a header it will not solve the problem, trust me I learnt the hard way. All that happened is the eliminator melted and fused to the header which resulted in about 120$ worth of repair costs (nothing serious, the O2 bung just to be cleaned up and the CEL eliminator had to be scraped off). It's possible your gauge is causing the problem, a bad O2, any number of things. Get the code pulled and then come back, it could be a real CEL that was simply covered up by the header CEL.
Old Jan 15, 2006 | 07:08 PM
true the cel has been on since about the summer time. I always thought it was the header but now that i think about it the shop that installed my header did the wrost freaking job possiable and i'm thinking the guy just f*cked the o2 sensor when installing the header.
Old Jan 16, 2006 | 08:46 AM
Go2fast's Avatar
Sounds to me like ur front 02 sensor is messed up. Get the code pulled and ull find out. Must likely its just bad and needs to be replaced. The back one should be fine and the box should elimin the cel.
Dont but it the front!!!! The front sensor reads A/F readings and the box just sends a voltage to the sensor to trick it.
Old Jan 16, 2006 | 09:03 AM
livelyjay's Avatar
A narrowband A/F gauge will jump all over the place during normal driving conditions. It does this because the stock narrowband O2 signal has a very limited range of voltages, and the readings jump all over the place.
If you know anyone around you with some sort of logging equipment, you can see the signal both O2 sensors are sending out. When I had my Lancer plus turbo kit, I had a check engine light because the pre-cat was no longer in the system. I bought an O2 sensor simulator from Summit Racing and installed it inline with the second O2 sensor. The code went away and never came back because the simulator output a flat signal and tells the ECU that the pre-cat is there. The simulators go for about $45 on Summit, but at least they work correctly.
Old Jan 16, 2006 | 09:06 AM
dbdude's Avatar
Get your code pulled for free at autozone. Let us know wich one it is.
Old Jan 16, 2006 | 09:12 AM
livelyjay's Avatar
If you end up needing a replacement, go to www.oxygensensors.com and pick up a universal one for just over $50.
Old Jan 16, 2006 | 10:23 AM
Walkingchaos's Avatar
i put my header on (Kamikaze) and got a CEL the second day out. The day after that i installed the RRM CEL Elim. I havent seen a CEL yet. and ive driven the crap outta my ride since then
Old Jan 16, 2006 | 01:12 PM
i just went to autozone and the guy said i had a blown fuse and the check engine code puller thing wouldn't work. so i went home and check every fuse in the damn car none of them are blown. wtf
Old Jan 17, 2006 | 02:45 PM
I said screw it i bought new front and rear 02 sensors. I hope this makes the light go out.
Old Jan 17, 2006 | 02:59 PM
turboDan's Avatar
This helps if your code is a P0420.I have tried everything and some work some of the time,this has yet to throw the CEL for me,and I am not the one selling these,nor is anyone I know.I bought it and it really works.Also,if you have an innovative Wide band they recommend these if you have problems "burning out" their o2 sensors,just go on their web site,looks the same but cost over twice as much.Hope this helps
Links http://cgi.ebay.com/ebaymotors/ws/eB...tem=8031073330
And here is link to innovative http://www.innovatemotorsports.com/x...cat=250&page=2
Old Jan 17, 2006 | 03:02 PM
sthiewes's Avatar
Since you have a header, flip your cat around. That is what I did. NEVER had a CEL plus I don't have to buy one of those CEL Eliminators either.
