Idle Problem
Old Jul 29, 2006 | 12:26 AM
uci.magilla's Avatar
Idle Problem
I have a 02 OZ, and this was my first time doing anything to a car. I put on a KN typhoon short ram intake. Everything went fine I did it myself and followed their instruction sheet exactly. However, when I started the car up it was not idling smooth. I was low on gas so I took it to fill it up. Right after i filled it, I turned the car on and it could not idle. I began to hold the car at 1000 rpms and it seemed like the problem went away. But now every time i put it into park it idles really low for a couple seconds and then shoots up to 1000 before it corrects itself. It has not shut off since, but I do want to know if anyone knows why it would seem to struggle when I go from drive to park and I can do anything to fix it? I’m guessing it has something to with the throttle line since that was moved when I was changing intakes.
Old Jul 29, 2006 | 12:28 AM
g0damy0uugly's Avatar
did you disconnect your battery before install? try resetting ecu? check all hoses
Old Jul 29, 2006 | 12:42 AM
I did disconnect the battery but how do u reset the ecu? im a complete n00b at this.
Old Jul 29, 2006 | 12:45 AM
that should be your problem then you did reset your ecu (disconnect the battery) so now its reset, your ecu is re-learning how you drive and stuff so for about a day your car will idle a little weird but it should be fine
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
Evo1001
May 30, 2017 06:42 PM
mctonyb
Sep 11, 2016 09:41 PM
Evo47
Dec 10, 2015 09:46 AM
RedLanEVO
Oct 19, 2008 10:07 AM
