H/U and Clock black out
Old Apr 29, 2003 | 12:42 AM
lancer02Josh's Avatar
Question H/U and Clock black out
ok so tonight i was driving to my work and i made a turn and me clock and H/U turned off, then i went sround another and it turned back on, then again i went ariound another and it turned off and hasnte come back on yet. Any idea what it could be????
Old Apr 29, 2003 | 01:36 AM
LancerO-Z's Avatar
Same thing happened to me. You need to replace the 10amp fuse under the hood in the fusebox behind the battery. It will be one of the ones in the yellow casing. It shows a little music symbol on the fuse map on the underside of the lid you remove. That should be your problem.
Old Apr 29, 2003 | 09:49 AM
well i went to change the fuse and there is this yellow bx around that and another fuse. i cant get that off and with that on i cant get the fuse out WTF.....
Old Apr 29, 2003 | 10:30 AM
uranium9v's Avatar
I lost all the lights from the clock down to the ashtray lights....same thing...it was a fuse. It isn't in the yellow ECU box though.
Old Apr 29, 2003 | 10:34 AM
no there is a box next to the ecu in the fuse box that has 2 10amp fuses in it and on the box lid it has the music symbol there.
Old Apr 29, 2003 | 03:33 PM
LancerO-Z's Avatar
You need to go to an auto parts store and buy a fuse remover. Basically it looks like a plastic set of tweezers. Ask the sale clerk at the desk if you can't find it. That fuse is nearly impossible to remove without it. Hope that helps.
Old Apr 29, 2003 | 03:56 PM
no fuses are inside a yellow box i just found out that you have to remove the whole box and that the fuses cannot be removed from it. uranium what fuse did you replace????
Old Apr 29, 2003 | 04:00 PM
himuraknshn3's Avatar
u can find the fuse tweezers where the lil compartment u store money in. it is rite next to the drivers' door rite under the mirror adjustment. just pop it off and the tweezers are rite behind it.....
Old Apr 29, 2003 | 04:05 PM
reddog's Avatar
I will have to investigate this, thanks for the info.
Old Apr 29, 2003 | 04:09 PM
uranium9v's Avatar
I don't recal...I actually bought a fuse puller (little plastic tweezers) that had a fuse tester on the end....found the dead one and replaced it.
Old Apr 29, 2003 | 04:15 PM
zlancer's Avatar
nonono i kno what ur saying...you have to pull up on the yellow thing holding the 2 fuses...then you can pull the fuse out..the radio is the first fuse coming from the front of the car. your gunna need like needle nose pliers to pull out the fuse...its a really dumb way of holding the fuses..whoever made that should be smacked. i dunno why thats even like that.
Old Apr 30, 2003 | 01:18 PM
ok thanks i ll try that hopefully it works i went to mitsu to get it fixed and they stopped because the say i had new speakers on in my rear deck. on the paper it says they found 100 fuse blown. what fuse is the 100 fuse???? oo and can you get those types of fuses at like pep boys or somethin or do you have to get them from mitsu thanks..
Old Apr 30, 2003 | 02:46 PM
zlancer's Avatar
are you sure its not a 10 fuse..meaning 10 amp i guess.....if its 100 fuse...i'm guessing that would mean 100 amp......and i dunno if the car has one unless its the main battery fuse...(i don't kno that rating) but then the car wouldn't start...and yes you can get these fueses at any autoparts store.....they are mini fuses...the small square ones with the 2 prongs coming out of it.....
also it is pretty hard to get those fuses out of the yellow holder.....you really gotta rip them out....a tip would be to pull it up...then get a very small flat head screwdriver and push the 2 clips holding the fuse in apart......you'll see what i mean......its a dumb design....
Old Apr 30, 2003 | 02:51 PM
i got the fuse out yeah either they ment 10 or 100 is a technical term for it. o and it was blown thanks im on my way to pep boys. what would i do without you guys lol thanks again
Old Apr 30, 2003 | 02:54 PM
zlancer's Avatar
lol yup no problem
