Catalytic Converter
Old May 16, 2003 | 08:31 AM
pisetup's Avatar
Exclamation Catalytic Converter
How do I remove that sensor from the catalytic converter?? I'm having a hard time getting my hands in that area and since the Auto Hobby Shop is about 3 blocks away, by the time I get there and get the Lancer on the lift, its freakin' HOT!!! Also, if you're looking at the cat as if you're driving, how do I remove the nut that is on the top right w/o burning my hand?? Anybody have any tips??
Old May 16, 2003 | 08:48 AM
Lil red '03's Avatar
Hey bro. You have to drop those bolts on the rubber mounts and lower the converter to get at them. I had to do that when I put on my test pipe. Hope this helps.
Junior
Old May 16, 2003 | 09:02 AM
pisetup's Avatar
First I removed the bolts from the rubber mounts but the Cat was so heavy that the sensor wire was getting pulled and I didnt want it to rip off. Any more suggestions??
Old May 16, 2003 | 09:58 AM
OZ_03's Avatar
I just used a regular open ended wrench to get the O2 sensor off, then i had to use a cutting torch to get the 4 bolts off.
Old May 16, 2003 | 10:19 AM
BallaOnBudget's Avatar
a lot of wd-40 a have big biceps like myself....i didnt take the cat down from the rubber mounts...nor did i used a cutting torched i used all the power from my 300 lb body and torque those mugs til they came off...the were rusted pretty severly...the o2 sensor i cut the wire on and took off once removed then spliced the wire back together...anybody know how hard it is for a 300 lb guy to work on a car only held up by a 3 ton jack...impossible...gd...i used a monkey wrench and got all 4 with it...but i almost busted a nut doing so
Old May 16, 2003 | 11:17 AM
I should've added that it was easier for me to leave the back end of the converter connected.
To remove the O2 socket I used a ton of WD and a O2 socket with a wrench over my ratchet.
Old May 16, 2003 | 11:56 AM
pisetup's Avatar
Ahh WD 40 is the key, I think...thanks guys for all the input. I'll try again tomorrow.
Old May 18, 2003 | 10:37 PM
J'sLancerLS's Avatar
I had absolutly no probs getting my cat off, socket with a breaker bar, popped those biatches loose like nothing! used an opened end wrench to get the O2 sensor off, had to hit the wrench a couple times to break it loose, but once it popped, undid it the rest of the way by hand!
Old May 19, 2003 | 12:53 AM
ghostrider's Avatar
You can also save yourself the risk of ripping the o2 sensor wiring out (careful, that piece is upwards of $300+ for a replacement ) and get an o2 sensor socket for $10.
As for how to get the nuts off, make like J'sLancer and get yourself a breaker bar. I mean, unless you WANT things to be difficult.
Old May 19, 2003 | 02:35 AM
crusin_lancer's Avatar
use muscle! I didn't have an openend wrench that big so I used an adjustable one and got it off in no time.
Old May 19, 2003 | 03:04 AM
liquidlancer's Avatar
IMPACT WRENCH!!!! but if you cant getthe o2 sensor off you should take it off the car its easy to work on it whne its out its a pain in the *** though
Old May 19, 2003 | 07:01 AM
Bitnode's Avatar
damn o2 sensors
Old May 19, 2003 | 07:19 AM
pisetup's Avatar
I got it off....muhahahahaha!!!! Didn't need WD40 or anything, it was just a matter of time and patience.
Old May 19, 2003 | 08:34 AM
As Cartman would say............. kickazz!!!!
dcdirtrider
Mar 21, 2017 12:15 PM
Blacksheepdj
Dec 2, 2016 08:31 AM
vle503
Mar 9, 2015 02:28 PM
kapture2k
Mar 22, 2012 01:27 PM
TTOPPOUZI
Dec 2, 2006 11:38 PM
