oil light comes on at idle?
Old Mar 22, 2010 | 02:55 PM
EdT's Avatar
EdT
Hey I am getting the same issue, oil light would flicker, but disappears when I step on the gas. I plugged my OBD and it gives NO code, checked oil level and it is full so no leaks. Any of you guy solved this problem ?, my '03 only has less than 60,000kms on it !
Old Mar 25, 2010 | 05:42 PM
turbolancer02's Avatar
crawl underneath and look up to the wire connector on the sensor, its right next to the filter , squeeze the clip n pull the wire off clean the tab on the sender with sandpaper to make it shiny put dielectric grease on the tab and reinstall the wire...
i work at mitsubishi and own 2 and a dodge that uses the mitsu sensor, they all corrode , the reason it goes out when you rev is the wire gets no vibration through the block or at least alot less then at idle , when the wire shakes it kicks on the light makin it flicker ...
its a bad enough design that my lancer will now get a autometer gauge along with my talon TsI
Option number 2 is your throttle body idle air control motor is sticky likely from years of ****ty gas and never being cleaned,
seafoam will not get to it to clean it totally!! and unfortunetly isnt a miracle cure for actually removing it and cleaning it Im sure it cannot be good for the mdp sensor either since liquid normally never touches it,
normal idle is around 800-900 at idle when warm...take off the iac clean it and reinstall it and you'll be good to go..
Old Mar 25, 2010 | 09:06 PM
EdT's Avatar
EdT
Thanks for the info, I replaced the OPS and it is all good now, I don't think it was a corroded blade terminal more a worn out OPS that is a known issue with Nile brand OPSs on Mitsu and Chrysler cars with Mitsu engines like the Seabring and yes I applied die electric grease on the blade and the screw holding the blade as always.
Old Apr 1, 2011 | 12:48 AM
Maverick158's Avatar
Back from the dead... the same flickering oil light just started happening to me. I'm assuming the OPS is going bad. The shop I have it at is doing an oil test to make sure there's no debris in it. They're telling me that if they find debris it means they'll essentially have to do a rebuild. I'm hoping its just the sending unit.
Capes
Feb 9, 2014 02:27 PM
AustinG
31
Sep 2, 2012 06:16 PM
WangMan
Lancer Engine Tech
Oct 30, 2011 04:59 PM
MitsuJDM
11
Sep 4, 2011 04:36 PM
N1te
Mar 23, 2010 03:04 PM
