problem with my engine
Old May 24, 2003 | 06:21 AM
Archangelite's Avatar
Hi, i need help. i have an 2002 oz lancer automatic. yesterday i felt a little lag in first gear, but after it switched to second i was fine. later that day i switched air filters, i have a short air intake. so after that i took off and then my car started choking as i pushed on the gas, not like it wanted to turn off but more like skipping . it was still drivable. now i wanted to know if maybe it is a spark plug, i have 30000 miles on it, but i changed them 1 month ago. the check engine light went on after it choked, didnt go off. could it be because i changed the filter that the mas has to settle? i dunno what it is, and i dont wanna take it to the dealer cuz then theyre gonna start bull****tin about the mods. all help appreciated.
Old May 24, 2003 | 06:25 AM
03LANCER's Avatar
the dealer cant really do anyrthing about an intake or exhaust anything voids warranty anyways check your plugs and injectors something might be clogging injectors ti apoint.
Old May 24, 2003 | 06:28 AM
well, i take care of my car, u know synthetic oil, good plugs and all. it might be the injector but i also put in gas treatment, so i dont know. if it is the injector, where is it so i could check it out or replace it.
Old May 26, 2003 | 12:01 AM
Unhappy Lancer is choking
i need dire help. my lancer starts to choke when i accelerate. i checked the intake, its fine. i checked the oil, synthetic is full and filter is new. i checked the sparks, theyre new too. i dont know what else it could be. HELPPPPPPP
Old May 27, 2003 | 09:22 PM
HobieKopek's Avatar
Any info on mods, recent mods etc would be helpful. Your registry entry seems to be missing what you just described so I'm assuming it's missing more as well.
Old May 27, 2003 | 09:29 PM
EvoLancerVll's Avatar
hmm...that happened to me when my plugs went bad but you said they are new...hmm...
Old May 27, 2003 | 09:37 PM
HobieKopek's Avatar
Could very well be the spark plugs are improperly gapped since they're new.
Old May 27, 2003 | 09:44 PM
nastea's Avatar
don't get mad, but you didn't remove that little block box on the intake did you
Old May 27, 2003 | 09:56 PM
WiDeFiRE's Avatar
It can be the spark plug cables too... I ran in a "small" pot hole the other day and lots of water went in my engine bay and water got on my spark plug cables. Spark plugs were new and my motor was running weird. Went to the shop, the guy change my cable and it's still running like new!
So, maybe it's only that. Cost me 20$ to fix... hehe not that bad!
Hope for you it's nothing serious!
Good Luck!
Old May 27, 2003 | 10:25 PM
blaze_125's Avatar
I had that kind of problem two times with my previous car. Two different cause each time.
First time, my MAS sensor was screwed up.
Second time, one of my new spark plug was improperly gaped.
Might be one of these.
Old May 27, 2003 | 10:33 PM
blaze_125's Avatar
Re: problem with my engine
Here is one thing you might want to try.
Unplug your negative wire from the battery for a good 15 minutes. That should restart the ecu. It might solve the problem.
When you installed your SRI, did you correctly hooked the MAS. You know that wire coming out from the top?
Old May 27, 2003 | 10:50 PM
Joka's Avatar
Unplug the positive terminal, not the negative.
Old May 27, 2003 | 11:46 PM
HobieKopek's Avatar
next time please use the thread you already made instead of creating a new one. Merging the two.
Old May 28, 2003 | 06:05 AM
i took it to the dealership and it turned out that one spark plug had a small little crack on it causing it to misfire. so thanx every1 for all the help. and sorry hobiekopek.
Old May 28, 2003 | 09:37 AM
blaze_125's Avatar
I've always done it with the negative, and it always worked
