Is my car safe?
Old Feb 21, 2007 | 01:05 AM
eyekyu's Avatar
Is my car safe?
Yeah, as you can see the bolt head is ripped off. I was in the middle of tighten this and boom.
Well the belts are still tight, it drives fine but i just worried something will happen. i have yet to find the part as i cant remove it.
Old Feb 21, 2007 | 09:08 AM
lancerman360's Avatar
Yeah you might want to replace that bolt. You dont want your alternator to be bouncing around. Other than that tensioner bolt, there is only one more holding it at the bottom. You have to loosen it before you turn the tensioner.
The mitsu dealer can order you that bolt.
Old Feb 21, 2007 | 09:47 AM
SLVROZ_03's Avatar
Yeah, the vibrations in the engine bay will cause problems there... Definitely get that replaced asap.
Old Feb 21, 2007 | 09:55 AM
Tech@SA573's Avatar
Hmmm...I guess I'm not the only one that had that problem. That's a horrible design on Mitsu's part. It doesn't take much force to snap the head off like that. I just found a bolt about the same length and the same threading and ground the threads off at the top to make it fit. Easy $.25 fix. However you do it, definitely get it fixed.
Old Feb 21, 2007 | 12:16 PM
eyekyu's Avatar
wait, what else do i have to loosen?
Old Feb 21, 2007 | 12:19 PM
impetus19's Avatar
Samething happened to my car... I never replaced the bolt.
that bolt is only used to adjust tension on the belt. there is another bolt that holds the alternator in place.
Old Mar 10, 2007 | 06:25 AM
kidney_bean's Avatar
Just an idea, but if that many people are having an issue with it, maybe you should let Mitsu know. They might come out with a TSB (or there might already be one)...it could even have them replace it for free if it's determined that there is enough of a problem with them...no promisses on that though...
Old Mar 10, 2007 | 10:35 AM
A bolt under the alternator. 14mm I believe. You have to have that one loose before you adjust the tensioner or the bolt will break. Looks like thats what you were doing.
Old Mar 10, 2007 | 10:39 AM
atilla's Avatar
i actually think i have all the pieces for the alternator tensioner... i WAS going to replace mine but i never bothered with it since mine was in good shape. i just bought it all when i had to replace my power steering tensioner components.
PM me if you'd like to buy the stuff off me. i can also get you a diagram and part numbers if you need 'em, too.
Old Mar 16, 2007 | 08:45 AM
krimson_binome's Avatar
It's been a while since I messed with this myself, but as I recall the two points that anchor the alternator are the previously mentioned bolt on the bottom and the bolt that goes through the side of the square block the tension adjustment bolt goes through. As long as both of those are tight you should be safe to drive. Just remember that you do need to loosen both before you can adjust the tension though. Although I could be wrong, I don't have my manual with me right now and I can't tell from the pictures.
Old Mar 28, 2007 | 06:00 PM
lucentex's Avatar
Man what were you trying to do to brake that off, your belt shouldn't be as tight as a guitar string.
joeymia
54
May 7, 2017 07:47 AM
mx4life85
24
Aug 24, 2014 07:57 AM
inphluence
May 28, 2008 12:23 PM
inphluence
Dec 26, 2007 11:27 PM
JuancaROD
Nov 7, 2006 06:26 AM
