HID xenon light problem
Old Apr 18, 2002 | 11:34 PM
JGAOZ's Avatar
Exclamation HID xenon light problem
hi, i recently installed some HID Xenon Bulbs on my lancer, I was wondering if anyone else has and if they have problems when the switch on their brights that they actually go dimmer. I switched the bulbs and I'm still having this problem, any help would be appreciated. thanks.
Old Apr 18, 2002 | 11:36 PM
pjal84's Avatar
If you put in true HID bulbs, the stock amount of power being fed to the lights simply isn't enough to power them.
Old Apr 18, 2002 | 11:39 PM
uranium9v's Avatar
I had the same problem....when using brights they were dimmer and more yellow....true not enough juice to power the higher voltage...you'll need to wire in a new fuse i believe. Someone correct me if im wrong
Old Apr 18, 2002 | 11:42 PM
pjal84's Avatar
I've seen bolt on HID capacitors that you can mount in the engine bay and feed your HIDs however, since I'm at work...can't really look to in depth in the matter.
Old Apr 27, 2002 | 01:47 AM
KMcW's Avatar
If you're running true HIDs you wouldn't need your brights, as for the Hiper, APC, Razo "HID" bulbs, they are setup to only run your low beams, hence the higher voltage. Hope that helps.
Old Apr 27, 2002 | 01:49 AM
KMcW's Avatar
Oh and "true HID" come with a mountable 'voltage booster' is what it amounts to really.
Old Apr 27, 2002 | 01:54 AM
2wdSQL's Avatar
True High Intensity Discharge lenses come as a complete package with a capacitor attached; they are complete replacement kits meaning you must remove your OEM lense to install them and cost I think $300/$600 a pair/piece if I'm not mistaken.
Old Apr 27, 2002 | 01:56 AM
2wdSQL's Avatar
The HID lense is also 24VDC I believe and to correct myself it comes with a STEP-UP transformer attached not a capacitor
Old Mar 11, 2007 | 07:09 PM
Gambitincognito's Avatar
where is a good, reliable place to get a set for my 2003 lancer oz rally?
Old Mar 28, 2007 | 08:30 PM
mrblob20's Avatar
Ummm, the hi-beams on HID`s can`t use the same bulb. There is probably another bulb attatched on the same housing which is a regualr halogen bulb that doubles for you hi beam. Thats how it is on mine...
And i installed a kit from ebay for $200, and it used stock fuses and didn`t require any extra power... and correct me if i`m wrong but HID`s use less average power than halogens anyways.. maybe right at the beginning its a spike...
Old Mar 30, 2007 | 08:37 AM
03_Lancer_ES's Avatar
Well if it's like normal electrical, then stepping up the voltage means that they work more efficiently, because you can put more wattage through the same size fuse.
Lukelis
Mar 23, 2017 11:27 PM
joonvang
Oct 31, 2016 04:09 AM
backwoodsRUNNER
13
May 24, 2012 08:15 PM
JaguarS4R
Sep 5, 2004 08:55 PM
jae_hung
Jan 31, 2004 12:58 PM
