PlasmaGlow lights
PlasmaGlow lights
Sup Guys,
I am planing to get a pair of headlight bulbs. i was looking at the 5500K XENON KRYPTON PLASMAGLOW HEADLIGHTS and JDM MTEC 9007 HID Super White Halogen Bulbs Hope you guys will would have any gd(or bad?) experiences on these bulbs. Or is there any gd suggestion??? My budget is really tight, wishing could get it under 40 bucks... Thanks guys`
long as they are standard wattages you should be ok with either, but if they use 80/100w you might wanna invest in a new wiring harness so you dont melt the stock one... most pep boys / autozone shops have em on shelf
I don't suggest using those "5500K" bulbs or the "HID white halogen bulbs." The term "HID halogen" is sorta an oxymoron.
I think you should just go get Sylvania Silversta halogen bulbs. They are white, not blue. A lot brighter than stock bulbs.
Originally posted by LaNceRiTiZ
i have plasma green bulbs....
not much difference from any other aftermarket bulbs
out there...
out there...
Thanks guys for ur suggestions...... t think both bulbs are using 66/55, so it wont be a problem. All i want to know is tt whether the bulbs are worth to buy or not~~ I dont want to spend so much bucks just to buy a normal headlight bulbs like the original one, tt really suck
To LaNceRiTiZ,
U said tt the plasma bulbs are no much diff... so is it bright enough??? or just as lousy as the stock bulbs???
Cheer Guys~~~~~~~~~~~
TxFAkuma
Sep 30, 2015 08:55 AM
