K&N Air Filter
Old Mar 9, 2007 | 01:02 PM
Jehuty's Avatar
K&N Air Filter
I just installed my K&N Typhoon intake, and now the car is being jumpy and almost dying, almost as if there is no filter at all, I have noclue what to do, I tihnk there might be a leak around the MAF sensor, but I'm unsure, because I tightened the screw beyond belief.
Old Mar 9, 2007 | 01:03 PM
ambystom01's Avatar
Did you reset the ECU?
Old Mar 9, 2007 | 01:04 PM
Jehuty's Avatar
yessah, and after I did that, the car was being worse, the SEL is gone though, lol. I connected the terminal back, so now I'm mad
Old Mar 9, 2007 | 01:22 PM
blaze_125's Avatar
So did you reconnect the harness before or after resetting the ecu?
Are you still experiencing problems?
Old Mar 9, 2007 | 01:24 PM
Jehuty's Avatar
After reconnecting, and yes I am
Old Mar 9, 2007 | 01:27 PM
blaze_125's Avatar
how long have you had the car idling for?
When I used to reset my ecu, it'd take a while before the rpm would settle.
Drive it around for a few clicks and see what happens.
Have you damaged the honeycomb looking thing at all during installation?
Old Mar 9, 2007 | 01:28 PM
Guyver's Avatar
edit: deleted
Old Mar 9, 2007 | 01:29 PM
Jehuty's Avatar
When I have it in park, the rpm go down, and my headlight look like they are about to shut off, and the first time, the car turned off. I never damaged it, and I've been driving it, and it's been alright, until I just got to work, and my car started up again
Old Mar 9, 2007 | 01:30 PM
blaze_125's Avatar
how long did you let it idle for?
ambystom01's Avatar
Wrong car guyver.
Old Mar 9, 2007 | 01:32 PM
Guyver's Avatar
Originally Posted by ambystom01
Wrong car guyver.
Yep just caught myself,
Apparently too late
Old Mar 9, 2007 | 01:37 PM
Jehuty's Avatar
lol, what car did u put, I didn't see....although I stil wanna know what to do -.-
Old Mar 9, 2007 | 01:41 PM
Danny23's Avatar
Your problem is the typhoon system. Its the worst intake you can put on an evo or a lancer. A k&N filter is perfectely fine,but the intake tube(typhoon) is a piece of junk. Take it off and just use a drop in filter in your stock air box and your car will run like its suppose to PERIOD!
Guyver's Avatar
I read the thread from the front page, assumed it was an evo
Old Mar 9, 2007 | 01:44 PM
blaze_125's Avatar
assuming the typhoon system is junk... I'd keep the filter and hook it directly on the maf.
