GTS Bluetooth Problems
Old Jun 28, 2007 | 02:59 PM
kevin_'s Avatar
When I call someone using the bluetooth and they pick up, it usually takes about a second or so before the system changes from "dialing" to call active, so there is a lag when you use it... which sucks b/c the person on the receiving end usually has to say hello like two or three times before I hear it...
Old Jul 2, 2007 | 07:31 PM
cruzzrr's Avatar
I have a BB 8700 - works fine, but there's almost always a significant delay when making a call and the person on the other end being able to hear me speak.. I usually have to wait a few seconds before speaking.
Old Jul 3, 2007 | 08:15 PM
ingballesteros's Avatar
I do had that problem... and tried to re-setup the phone with the car - didn't work... the solution was to re-start the phone... now just works fine as it did before the problem...
Old Jul 8, 2007 | 08:09 AM
carasage's Avatar
sorry for highjacking the thread... but anyone else getting reconnect issues w/ the car and phone?
I have the blackberry pearl paired and every single time i start the car i would need to go to the 'setup bluetooth' option in the pearl and would need to manually CONNECT to the bluetooth handfree device...
Should this be automatic when the car is started? its annoying to have to use my phone to connect everytime i enter my car.
anyone else having problems like this?
Old Jul 9, 2007 | 05:08 AM
GTS_rider's Avatar
^^ yeap, Mine reconnects automaticly as long as my phone's bluetooth is active... I did notice that if the Bluetooth is "off" and I turn it "on" after the car is running.. it won't connect.. but, since I usually have my bluetooth function "on".. I have not issues...
Old Jul 9, 2007 | 05:10 AM
GTS_rider's Avatar
by the way... I have the samsung U740
Old Jul 9, 2007 | 06:48 AM
gnnr's Avatar
If your BT was off and you turn it on just hit the call button to have the system force a connect if it failed to link up when you turned BT on.
Our works great. I have a traditional flip Moto (Forget the model) that's relatively high end and my wife has a pink Razor V2. Both are setup on BT. If we are both in the car it recognizes mine first, but asks if this is the phone you want and you can switch. It's very slick.
Old Jul 9, 2007 | 02:14 PM
Blacksheepdj's Avatar
Nice. I might have to play with it one of these days...
Old Jul 12, 2007 | 11:08 AM
jonnyweb's Avatar
I have the LG V (verizon) not the N V which is the newer model, but last years.
Havent had any issues w/ the bluetooth at all.
Hope you're able to get yours working, I'm sure its a pain in the ****
Old Jul 15, 2007 | 08:59 PM
Hagbard's Avatar
Have a BB 8700 (Rogers in Canada)No problems with it loseing connection but i have that slight delay before i can talk and it says call Active, never had anything to use with the BT in my phone so i just firgued thats the way it worked. No other BT stuff at all in the car. 3 weeks now i have had the car. Love the hands free and the call ID accoss the radio.
Old Jul 25, 2007 | 06:13 PM
carasage's Avatar
anyone know how to transfer your phone book to the nav/hands free system?
Old Jul 25, 2007 | 06:32 PM
nawtyboy03's Avatar
Registered User
i cannot answer calls, my phone rings but it doesnt come across saying incoming call on the car, i can dial out, call numbers in the phonebook but no answering, i have the razr v3m. any ideas
thanks
ocase
Aug 5, 2016 01:22 PM
Mike01gsr
Oct 13, 2007 09:59 AM
spoonerr
22
Jan 26, 2007 01:27 PM
David Buschur
77
Feb 7, 2006 03:38 PM
Incognito
21
Jun 27, 2003 03:53 AM
