D*mn Bolts
PB blaster did the trick on the front 2 bolts for me, but the back 2 were just impossible! i took it to a shop and had them loosen the back 2 bolts and the o2 sensor.
that... also saved me hours and a ton of curse words! haha ... or even more than were already said..
did you actually buy a gator grip or did you borrow it from a toyota owner.
tips i have fro exahaust removal:
1) clean exposed threads with wire brush
2) deep penatrting oil (dura lube // wd-40 // 2n1)
3) tighten just a tad before you loosen
4) heat
5) tapping (not whaling) with small mallet
6) use only 6 sided socket OF THE CORRECT SIZE
repeat steps 2-5 as often as nessecery
4) heat
ezzey
Aug 21, 2015 06:12 AM
pjb00stin
Dec 24, 2008 05:22 PM
webguy330i
Aug 23, 2005 07:55 AM
