my a/c exploded
Old Aug 14, 2007 | 04:23 PM
initialDRacer's Avatar
my a/c exploded
Ok, I was driving and minding my own business and I had my a/c on to level 1 when all the sudden something happened. There was a small pop and then suddenly there was this white cloud of smoke coming out of the passenger side front hood. I stopped immediately to the side hoping it wasn't anything serious. I opened the hood and oil was leaking and looked like it exploded inside the engine bay on the passenger side. I smelled what kind of oil it was but it kind of ressembles baby oil or cooking oil. The hissing sound continues (maybe all the frion is leaking out?) for about 5 minutes until it's all quiet. I tried to turn on my a/c again and it no longer blows cold air. I let the A/C run for 5minutes and it's making this hissing sound. However, I can still drive my car. Any ideas what could be wrong??
Old Aug 14, 2007 | 04:36 PM
stryfetew's Avatar
Sounds like a line poped.
Old Aug 14, 2007 | 06:54 PM
SLVROZ_03's Avatar
Sounds like you blew the welds on your intake!
Old Aug 14, 2007 | 07:09 PM
TIBOevo's Avatar
screw it. rip the air conditioning sytem out, shave some weight and gain somemore throttle response!
Old Aug 14, 2007 | 07:20 PM
fyreant's Avatar
ROFL
Old Aug 14, 2007 | 07:26 PM
eehjay's Avatar
definately sounds like a line popped. did you check if any of them were disconnected/torn/damaged or anything? possibly at the crimp points.
Old Aug 14, 2007 | 07:32 PM
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
hahah clasic F&F
Old Aug 14, 2007 | 07:39 PM
I'm not sure where to check it. Does anyone have a picture diagram of the air condition system?
Old Aug 15, 2007 | 06:10 AM
blaze_125's Avatar
You mean you saw a cloud coming out of the engine bay and you didn't bother pin pointing where it was coming from?
Then get an AC recharge kit and see where it leaks.
Old Aug 15, 2007 | 08:26 AM
I was looking in the engine bay and I couldn't tell where it was coming from. I was tracing back the source of the oil leak and it's dripping somewhere between the manifold and passenger front tire. There is a motorized device (which is connected to a pully belt) around there that may be the culprit. Leak stopped but I can still hear a hissing sound when I turn on the a/c.
Old Aug 15, 2007 | 10:49 AM
denver's Avatar
Have you ever, or had anyone, charge your A/C system?
You either blew a hose, or an O-ring where the lines come in and out of the compressor. Typicly your A/C system wont just randomly blow up unless something else happend, and if you had the system checked or charged they possibly put to much refriderant in and over pressurized the system. Either way you have to find the leak, fix it, replace your Dryer and have the system recharged.
Old Aug 15, 2007 | 12:29 PM
blaze_125's Avatar
Would you be able to post a picture of the area?
Old Aug 18, 2007 | 12:49 PM
Here you go... I found the problem. I need to replace or patch the hose (circuled yellow). It's rubbing against the other metal hose (circuled blue). Where do I get this hose and what is it called? Can I get an upgraded one?
Old Aug 18, 2007 | 07:07 PM
eyekyu's Avatar
something similar happened to me to day, was driving with my a/c on going about 80mph (note// my a/c blows warm and cold, on going problem) and i smell this burning rubber. I get off on the off ramp then this white cloud of smoke comes from my car, i end up pulling over and this sucker was bright red.
Old Aug 21, 2007 | 02:24 PM
Chizilds's Avatar
Looks like the mad scientist is gonna have to rip apart the block, and replace the piston rings he fried!
