Car still not runnin(HELP)
Old Aug 30, 2007 | 02:13 PM
bigric09's Avatar
that goes to the other side of your fuel tank.... buschur has a few comments about what that does somewhere in their double or triple fuel pump posts. Nothing to worry about for you in either case
if you dont have that black rubber piece under your pump, i guarantee thats the problem
Old Aug 30, 2007 | 02:22 PM
zay's Avatar
zay
will that little black piece keep it from working because i didn't have it on because the pump was different on the bottom and the bottom plastic piece didn't click back on
Old Aug 30, 2007 | 02:31 PM
bigric09's Avatar
yes it will... because the pump even though it looks like it, doesnt seat all the way and you dont get a good seal. use your stock one if you have to, make it fit..... you need that to help it seal
Old Aug 30, 2007 | 03:05 PM
zay's Avatar
zay
the new fuel pump i got the walbro didn't come with the black piece or anything like that just the pump and also my car turns over once and then doesn't crank anymore and I still have the stock battery could that be the problem
Old Aug 31, 2007 | 07:23 AM
bigric09's Avatar
NO.... you have to have that plastic piece under the pump or it WONT seal. You will either need to buy a install kit, fab some piece of something to put underneath the pump to help keep it sealed. The reason the car turned over once is because it was trying to crank with the remaining fuel in the line.... im guessing you didnt pull the relay fuse with the car running and then crank it a few times after it died to help run all the fuel out of the line.
Old Aug 31, 2007 | 07:33 PM
zay's Avatar
zay
No I didn't do that but I put the black piece back on and still nothin but I dont think the batt is getting any juice because after I charge it and put on the positive and then just touch the negative it doesn't spark
Old Aug 31, 2007 | 09:12 PM
bigric09's Avatar
lol.... you need a multimeter.... tracing voltage without one is like a blind guy trying to tell you if its dark outside.
Old Sep 1, 2007 | 09:32 PM
zay's Avatar
zay
lol I see this is hard work but I'm gonna take your advice and get one but could that battery be the prob its just too weak to give the fuel pump any juice
Old Sep 1, 2007 | 09:36 PM
bigric09's Avatar
fuel pump needs 12 vdc.... if your battery is dead, obviously it wont work, nor should anything else in your car really.
Old Sep 1, 2007 | 09:41 PM
SaOrlando's Avatar
do you realize it is not an evo?
Old Sep 1, 2007 | 10:35 PM
bigric09's Avatar
yep... evo is based off of the lancer, some things arent going to be that different
Old Sep 1, 2007 | 10:50 PM
EvoInvidia's Avatar
He installed everything back right? If there even fuel in the tank? Does the car have power at all, why would his battery be dead after a fuel pump install? Is everything on tightly and securely?
Old Sep 2, 2007 | 04:35 PM
zay's Avatar
zay
everything in the car works like radio and all that but its still the stock battery about 2 years old and there's fuel in the tank and everything is secure so I'm gonna buy a stronger batt and see if it makes a difference cause it might be a dead cell in the battery
Old Sep 11, 2007 | 01:30 AM
EvoInvidia's Avatar
update?
Old Sep 12, 2007 | 05:26 PM
zay's Avatar
zay
still isn't runnin i changed the fuel pump but its not working and the plastic piece on the bottom doesn't stay because i had to modify it because i got a walbro fuel pump
