Car still not runnin(HELP)
Old Aug 30, 2007 | 11:39 AM
zay's Avatar
zay
I'm not getting any fuel to the front but I just put in a walbro fuel pump since the other one stopped working any ideas what can be the prob my fuse for it is good I'm at a stand still any suggestions
Old Aug 30, 2007 | 11:40 AM
bigric09's Avatar
throwing any codes ?
Old Aug 30, 2007 | 12:57 PM
zay's Avatar
zay
no code machine or anything cant get it to crank it will start up for like half a second and then cut off I was looking for the fuel filter but I cant find it
Old Aug 30, 2007 | 01:18 PM
SLVROZ_03's Avatar
The fuel filter is the in-tank pump/"sock" combo... Good luck!
Old Aug 30, 2007 | 01:20 PM
zay's Avatar
zay
so its part of the fuel pump or is it the thing on the bottom of the whole thing
Old Aug 30, 2007 | 01:35 PM
bigric09's Avatar
the thing on the bottom... the mesh bag around the bottom of the pump. you need to get a code puller..... sounds to me like the cam position sensor but, no code... .no help. do you have a light on ?
Old Aug 30, 2007 | 01:42 PM
zay's Avatar
zay
CEL comes on but it doesn't stay on long enough for me to know what lights are on and I checked that bag and its clear besides the gas
Old Aug 30, 2007 | 01:43 PM
zay's Avatar
zay
The only way to fix the cam position sensor is to replace or is there a way
Old Aug 30, 2007 | 01:45 PM
bigric09's Avatar
you can pull it off and spray it with brake cleen to clean it. Also you can pull your valve cover and check your cam and make sure it is seated properly and nothing is wrong. We had a car here recently with that code and turned out the cam had broken off from the bolt holding it on the sensor side
your mod list would help... what kind of cams if any ?
Old Aug 30, 2007 | 01:54 PM
zay's Avatar
zay
no cam upgrades i just have the normal like headers, exhaust, ngk plugs, weaponr intake, engine breather, thats about it and where is the sensor at
Old Aug 30, 2007 | 01:56 PM
bigric09's Avatar
if you look at your valve cover, on the right side front there is a little black thing in front with a wire running off it that has a circle connector on it that is grounded with a screw that points to the left. i think the wire is black and green maybe. You need to unscrew that and the single screw that holds the sensor in place....so do you have a SES light or not ? if its there, it will stay there
Old Aug 30, 2007 | 01:58 PM
bigric09's Avatar
also check other fuses, ecu fuse, the fuel pump fuse... did you put the pump in correctly ? can you hear it whining when you first turn the key and here it priming ? did you use the rubber piece under the pump to keep the pump pushed up against the seal ? recheck your pump again as well to make sure it is still connected. Use a multimeter to check the voltage at the connector going to the pump. you should see at least 12 volts....if you dont, its your ecu or a fuse pulling votage
Old Aug 30, 2007 | 02:00 PM
zay's Avatar
zay
No I dont have that well i've never seen it before and all i have to do is take that sensor off and spray it
Old Aug 30, 2007 | 02:05 PM
bigric09's Avatar
wipe it off yes, and spray inside the hole it came out of.... you really need to get your hands on a multimeter.
and you dont have what ? the black thing pushing up on the pump ? if not, it may not be black... there should be a rubber thing that pushes up on the bottom of your pump when you close the plastic shell around it
Old Aug 30, 2007 | 02:09 PM
zay's Avatar
zay
yeah I've checked the fuses and they are all good but I had another question whats the the on the other side of the fuel pump under that other silver gray cover
