aftermarket tailight problem.
Old Nov 5, 2007 | 12:32 PM
socomplete's Avatar
I'm having a problem with my reverse light coming on and when i put my right turn signal on it just clicks real fast, and the signal does not come on does anyone know how to fix it or any links? thank you.
Old Nov 5, 2007 | 12:36 PM
ambystom01's Avatar
Sounds like a bulb is burnt out.
Old Nov 5, 2007 | 12:40 PM
socomplete's Avatar
I changed the bulb with ones that work and the reverse light on the right tailight doesn't work still. This place near my house said they would charge 80$ an hour to repair it thats psycho!!
Old Nov 5, 2007 | 12:41 PM
ambystom01's Avatar
Try swapping in the stock lights, that'll at least let you narrow down the problem (ie. is it the lights that are the problem or is there something else at work).
Old Nov 5, 2007 | 06:42 PM
socomplete's Avatar
It has to be the actual tailight that is the problem because I've changed out all of the working stock bulbs with the bulbs that came with the tailights. I think its definetaly the actual tailight curcuit or something. should i rewire it or something?
Old Nov 5, 2007 | 06:52 PM
ambystom01's Avatar
I wouldn't recommend that you try to rewire it. It might be time to take it to a shop.
Old Nov 5, 2007 | 07:08 PM
socomplete's Avatar
Yeah I just gotta shell out $89 bucks and stop being cheap. Here's a tip for you guys don't buy tailights from rrm.
Old Nov 5, 2007 | 07:16 PM
mixmasta's Avatar
I had that same problem before when I put mirror signals on another car. It acted like a blown bulb, but when I wired it, a sharp edge of metal cut through the insullation and I guess was grounding it out. Check make sure there arent any wires touching metal.
Old Nov 5, 2007 | 07:36 PM
socomplete's Avatar
'll try that out but from what I've seen the stock tailights seem to work best so I might just change the theme I have going with my car and do like a white red type color scheme I don't know.I'm frustrated.Pics soon by the way.
iel322
Lancer Troubleshooting
11
Oct 8, 2011 06:32 PM
Luke18
Nov 2, 2009 05:39 AM
Fourdoor
Oct 31, 2009 12:14 PM
dsings14
10
Oct 19, 2006 09:10 AM
ozlancer0z
11
Dec 4, 2004 10:47 PM
