Big Problems
Old Dec 11, 2007 | 09:47 PM
DemisedGabe's Avatar
Big Problems
Well to clarify the problem that i am having, I turn to the gurus and other respected members of this forum to help me out.
Before i Go any further mods are as follows:
Intake
Header
exhuast
Ported IM
bored Fuel rail
pulley
Cam
Piggyback v2
Spark Plug wires
testpipe
The car keeps shutting off at red lights, stops, etc..Started about sunday, so i took off my ground kit (thinking theres a bad wire) and put on the regular cables to the battery.
Monday still shutting off and im starting to notice that no matter what speed im going, When i press the clutch, the rpm's drop all the way down and shuts off...So im very frustrated as it is.
So i go ahead and buy new spark plugs and coil packs and install them.But no luck..and i also am noticing that it only seems to do it when the engine is already warmed up....For example, it will run fine when its cold but then 5 mins later when the engine is warm it shuts off..
To top it off, this morning on my way to 2 finals, my damn cd player and clock in my car surprisingly shut off and are not working..I buy new fuses but still no luck.
HELP!!!
Old Dec 12, 2007 | 07:43 AM
bump.
Old Dec 12, 2007 | 08:02 AM
senate6268's Avatar
Does it idle really low and rough trying to staying running and then just dies out? Or does it instantly die out just as quick as it turned on?
Old Dec 12, 2007 | 01:48 PM
yah it idles real low and tries to stay on.but turns off...even while im driving..if i press the clutch, the rpm's will go all the way down and turn off...i dont think its the piggyback, the connections are pretty sollid
Old Dec 12, 2007 | 02:42 PM
lancerrally45's Avatar
have you messed around with our idle screw at all?
Old Dec 12, 2007 | 03:33 PM
ambystom01's Avatar
Have you tried removing the piggyback?
Old Dec 12, 2007 | 09:02 PM
i havent messed with idle screw or removed pb..i might as well try removing pb.and see what happens...my mechanic put some kind of formula in my gas to clean the sensors and stuff...he said it will make idle jump around and to finish the tank and see how it runs.
Old Dec 12, 2007 | 09:11 PM
to clean what sensors?
Old Dec 12, 2007 | 09:18 PM
JDMLancerEvoVII's Avatar
Just bring your car to your local dealership and they will check your car which your car should cover under warranty.
Old Dec 13, 2007 | 09:08 AM
well i dont have any type of warranty with the dealership, and think the sensors its clean are along the lines of oxygen sensor, idle sensor.
Old Dec 13, 2007 | 09:22 AM
senate6268's Avatar
You stated that you removed your ground wire kit. Are you 100% sure that the factory ground wires are connected and in the correct locations?
Old Dec 13, 2007 | 09:42 AM
ihearthondas's Avatar
ever considered it could be your maf? just a suggestion b/c i had the stalling out problem and it turned out to be the maf sensor.
Old Dec 13, 2007 | 09:48 AM
slipshft's Avatar
have you checked (and rechecked) your ground? I would also look at your charging circuit. Then your battery. The clock and CD shutting off, was that while it was running or with just the key on?
It is possible that you have a intermittant short in the system somewhere that is killing your power.
Hope this helps.
Old Dec 13, 2007 | 09:49 AM
crypto's Avatar
Former Vendor
i say remove your piggy. I had similar problems with mine installed. Although you may want to retune it, you have a decent amount of mods, so it'd probably be a good idea to retune for them.
Old Dec 13, 2007 | 12:16 PM
As for battery, 5 mos. old. and for cd player..running or with key in they both dont work..my mechanic said it might be a wire cus he would put in a fuse and it would burn out.i dk...Yah i cant fine that damn cable to connect to my laptop...WHere do u get it?
