weird noise
Old Jul 22, 2003 | 02:21 PM
QuY RaCeR's Avatar
Unhappy weird noise
For the past few months, my lancer has been making this clunky noise whenever i come back from a drive. I figured its because i need a tune-up but i took it to mitsu and got a 30k tune-up and asked them to check out the noise for me. i got a call back the same day saying that my tune-up is done but they didn't find any clunky noise. They said that the sound is probably the a/c fan running. It makes the sound even with the fan off. Besides, the sound is comming from the back of the engine and i can really hear it when i put my ear to the front left wheel well. HELP??
Old Jul 22, 2003 | 02:36 PM
Sailorgoon's Avatar
So wait...this noise keeps happening? It's not just when you shut off the car?
When exactly is it happening? You already said no air, so we know that. If mitsu just did a tune it, it couldn't be a belt. Is the car stock? I know my short ram made noise like that before it was really tightened down.
You might want to check the airbox, and make sure it's not moving around on you. If you have subs, make sure the wiring from the battery is tight and not bouncing around.
You could always look and see if you have a squirrel stuck in the fenderwell, I guess...
Old Jul 22, 2003 | 02:50 PM
YellowOZLancer's Avatar
check all your bolts on your cai to make sure it isnt moving around when u shut your car off, it most likely has sumthin to do with your cai check it over once or twice to make sure everything is ok.....
illizit's Avatar
can u describe the noise a lil more? A get a wierd noise from my front passanger wheel when i brake from 30MPH and down..it sounds like sanding something with sandpaper....is that normal? lol
Old Jul 22, 2003 | 04:32 PM
nasdale's Avatar
illizit, that sounds like worn brake pads, how many miles do you have?
Old Jul 22, 2003 | 04:55 PM
HobieKopek's Avatar
Testify. That's the sound my car made whenever the engine torqued after this happened:
Old Jul 22, 2003 | 08:32 PM
illizit's Avatar
yeah..but i just changed them like 2 months ago, i have 25k miles right now..changed them around 22k. I think its the dust shield thats hitting the rotor or something..I have no clue..
Old Jul 23, 2003 | 02:36 PM
nasdale's Avatar
Well, I am out of ideas for now, good luck finding the source!!!
Old Jul 24, 2003 | 02:15 PM
MelissaOZ's Avatar
Does it do it when you are driving or sitting in one spot. I had my cv joint go bad on mine about 25000. front right I belive.
Old Jul 24, 2003 | 02:32 PM
illizit's Avatar
does it while im braking from like 30 mph. Doesn't do it any where else
Old Jul 24, 2003 | 03:26 PM
MelissaOZ's Avatar
Thats what mine did.
Old Jul 24, 2003 | 03:29 PM
illizit's Avatar
a cv joint bad already?! wow...
Old Jul 24, 2003 | 10:39 PM
pjal84's Avatar
If it only occurs after you drive and you kill the ignition, it could just be some relays shutting down.
Old Jul 25, 2003 | 07:30 AM
illizit's Avatar
no no..it doesn't do it while i'm stopped or idling w/e. It ONLY makes that noise when I press on my brakes while i'm driving.
crckheadjed
Jun 19, 2026 12:15 PM
coollol123
Lancer Troubleshooting
Nov 20, 2012 07:45 AM
Diego 10
Jun 24, 2010 01:40 PM
Derek888
15
Nov 28, 2005 12:04 AM
neyugn_naut
Apr 25, 2005 08:36 AM
