No Spark, Car Won't Start
Old Feb 11, 2008 | 11:16 PM
lancerrally45's Avatar
Well my car decided to not start up today. i pulled the plugs and they were covered with gas. So im getting gas. I replaced the spark plugs just to make sure and it still never started. By that time i had to go to school and had no time to mess with it. Once i got outa class at 12 i pulled the spark plugs again and checked to see if there was spark. no spark. how can 2 coil packs go out? is there a fuse linking them both together? any help is welcomed.
Old Feb 11, 2008 | 11:34 PM
KcEvil8's Avatar
is your check engine light on? you should go check for code. your probably have a bad crank sensor.
Old Feb 11, 2008 | 11:36 PM
none showed up yet. ill check again tomorrow
Old Feb 11, 2008 | 11:37 PM
oh. prior to this the car started up for about 4-5 seconds then shut right off. this is what followed
Old Feb 12, 2008 | 08:59 AM
anyone else have any ideas?
Old Feb 12, 2008 | 09:14 AM
i just checked the coil packs and both are at 9k ohms, which is within the spec.
Old Feb 12, 2008 | 01:35 PM
SLVROZ_03's Avatar
Not the CPS because you wouldn't even get fuel if you were having trouble with it. LOL, I would know cuz until I'd clean mine off it'd not start randomly.
Old Feb 12, 2008 | 01:46 PM
sharkm87's Avatar
idk bro...just need spark/ fuel/ and ecu telling it when to fire that bad boy....
odd you are gettin no CEL...maybe its the ecu???....
Old Feb 12, 2008 | 09:19 PM
how come it wouldnt be the crank sensor. thats the only thing that makes sence to me.
Old Feb 12, 2008 | 10:05 PM
the #1 fuse under the steering wheel is good. i just check it. and i reflashed my ecu just to make sure that wasnt it. crank position sensor is the only thing i think it can be, maybe becides a relay
Old Feb 13, 2008 | 12:29 PM
SLVROZ_03's Avatar
^Well, it's worth a can of brake clean to find out! If you feel daring, just drill a hole above the sensor (remember that the wire leading to it is held by the cover!) and spray away!
Old Feb 13, 2008 | 09:42 PM
well i think while im down there im going to put on a new belt and sensor. but i dont want to do this untill i know for a fact that the cps is for sure bad. the only way i can do that is by putting it on a scope.
no code came up yet
Old Feb 14, 2008 | 08:57 AM
bump..... for anymore opinions
Old Feb 14, 2008 | 05:33 PM
SLVROZ_03's Avatar
Only once did I get the CEL when the CPS acted up. Lucky for me the CEL stayed until I made it to AutoZone. If I added up the number of times it wouldn't start for this "problem", maybe a hand-full?
Old Feb 21, 2008 | 08:56 PM
pr0ph37's Avatar
If you find a solution for this lemme know bcuz my car is sitting in the driveway now with the same problem, im a few steps behind. tomarrow im changing the plugs but just in case....
