walboro fuel pump not pumping
Old Mar 21, 2008 | 07:43 PM
kansaslancer02's Avatar
Okay, found out my fuel pump is going bad so I had put the 255 I had and swapped it and now car won't start. I hear the fuel pump wining so I took of the line directly off the fuel pump and its not even pumping fuel. Does the new fuel pump need to be primed in anyway? Or maybe I just got a bad new Walboro?
I put my old one back in and now my car won't even start. I heard you have to blow out the return line. I'm going to try that out tomorrow but still need some help with the new fuel pump because my car won't go over 65 in 5th gear because it cuts out. Thanks.
Old Mar 22, 2008 | 12:33 PM
okay, did the blow test and still nothing. The fuel pump is pushing fuel out but my car is still not starting. The car starts for a second and then chokes to death. If i pump the gas pedal it will stay started but it stays around 500rpm. As soon as I let of the gas it will die. I read a forum and the guy was having the same exact problems and all he had to do was blow air through the return line. Any thoughts?
Old Mar 22, 2008 | 04:13 PM
compression, plugs are fine, new stock fuel pump installed and same problem.
Timing is good as well. HELP!!!
Old Mar 22, 2008 | 10:14 PM
I guess I will have to take it to the stealership on monday. Its gotta be something electrical.
Old Apr 10, 2008 | 04:53 AM
sharkcus's Avatar
Ever figure this one out?
Old Apr 10, 2008 | 06:01 AM
lancer2show's Avatar
i had this same problem one time. i d/c the fuel pump again and put it back on. than my car started. are you boosted?
Old Apr 10, 2008 | 07:15 AM
wd_cross's Avatar
are you sure you got the right pump? 255lph? mine was a bxtch to put in.. it wasn't like i could pop the stock one (WITH BRACKETS) and then take it out, replace it with the 255 (WITH STOCK BRACKETS) back and forth. i had to basically jam the 255 into the bracket and then pop it back in...
also do you smell gas in the back seats? is anything leaking? i doubt it's electrical..?
Old Apr 10, 2008 | 12:27 PM
SLVROZ_03's Avatar
Could the FPR been stuck open?
Old Apr 10, 2008 | 01:45 PM
xtreme5369's Avatar
I had the same problem with my 255 walbro, my mechanic went crazy figuring it out, finally gave it some "love taps" and bam shot fuel out. Sometimes they get stuck try it maybe it will work
Old Apr 10, 2008 | 03:55 PM
SLVROZ_03's Avatar
LOL @ love taps! I had to do that on my main relay on one of my Civics.
Max Daniel
Apr 12, 2017 11:25 AM
KevinD
33
Jan 16, 2017 01:19 PM
MechNARP
Oct 8, 2015 06:59 AM
Racer1
Feb 28, 2005 08:32 PM
GOKOU
Nov 13, 2004 06:51 AM
