Bogging and cylinder misfires in 2002 ES
Old Apr 19, 2008 | 11:59 PM
caedar's Avatar
I've been getting some power-loss, bogging, and cylinder misfires if I try to accelerate faster than grandma-pace when my RPMs are lower than 2-2.2k in my manual 2002 ES. I've replaced the sparkplugs with Bosch ones, but that didn't seem to solve the problem. Besides replacing the fuel filter and spark plug wires, would you guys suggest checking anything else out?
Old Apr 20, 2008 | 12:13 AM
senate6268's Avatar
Do you have any modifications to the engine or is it completely stock? More information is needed other than "my car bogs down."
Old Apr 20, 2008 | 12:27 AM
I'm blue's Avatar
Mass air flow sensor could be dirty, coils might be bad, if modified you might be going rich on that rpm. thats all i can think of hope I help.
Old Apr 20, 2008 | 01:52 AM
caedar's Avatar
I put in a K&N SRI, but this issue was occurring even before then. I was hoping that the increased airflow might help with the problem, but it hasn't done anything. Besides that, it doesn't have any mods.
Old Apr 20, 2008 | 12:45 PM
darkmitsu's Avatar
i think it might be a good idea to clean up all electrical contacts (battery terminals, all grounding points, ect.) then change to ngk spark plugs(bkr6es is the model i think but just make sure you get the ones that end in es) and make sure they are gapped correctly, replace your 2 spark plug wires also, then go ahead and change the fuel filter, if it still has problems after that you can try changing the fuel pump(maybe its not getting enough fuel). could also just be a bad tank of gas. how about trying to change your oil out to some fresh 5w30 and see if that helps any. there is many many things you can try for that issue. basically start with doing a tune-up and go from there...
Old Apr 24, 2008 | 09:24 PM
RULancerOZ's Avatar
I had the same problem
I had the exact same problem in my '02. Tried changing the spark plugs a few times, some other crap the dealer tried to do. Finally I just ordered both ignition coils, swapped 'em out, and the problem was solved.
Old Apr 24, 2008 | 10:49 PM
sykou's Avatar
Could be a vacuum leak... check to make sure you have no leaks where the injectors meet the fuel rail..
Old Apr 25, 2008 | 07:02 AM
darkmitsu's Avatar
old plug wires (cracked boots)could leak water into where the spark plugs go and that water could cause it. it happened on a crx of my brothers and it was shooting flames out of the exhaust because of unburnt gas it could spark on but 2 of the cylinders.
Old Apr 25, 2008 | 07:43 AM
senate6268's Avatar
Everyone here has given spot-on advice. Have you tried any of the suggestions? Have there been any improvements to your engine since trying any of them? Updates?
Old Apr 26, 2008 | 12:35 PM
Synthrocker's Avatar
good advice, cept fuel filter. Fuel filter *IM PRETTY SURE* is part of the fuel pump on these cars. No external filter.
But ya. start with puttin in FACTORY NGK plugs, gapped to .39-.43.
Some reason, ive heard our cars dont like bosch
Old Apr 26, 2008 | 01:22 PM
caedar's Avatar
I'm going to be cleaning the electrical contacts and putting in the new plugs today, I'll let you guys know.
Old Apr 26, 2008 | 02:06 PM
lancerrally45's Avatar
what gear are you in when your accelerating from 2 grand? just wondering.
Old Apr 26, 2008 | 05:27 PM
caedar's Avatar
I think I may have figured out the problem. The car accelerates fine after replacing the spark plugs and cleaning the contacts, but here's the deal:
When I pulled out the Bosch plugs that I put in only a month or so ago, they looked a little more worn than they should have. I inspected them a little more, and realized that they looked oil-fouled. Interestingly enough, the Bosch plugs worked fine for the first week or so, and then the same problem stated happening. Using this information, I've come to the conclusion that I'm overfilling my engine oil. Some people say use 5 quarts, some say use 4 quarts. I'm going to change my oil level to 4 quarts and see if it begins to stall in a week or two.
Old Apr 28, 2008 | 03:33 AM
If you have a 2.0, its 4Qts and if youve been using 5, you have been over filling, that could cause oil to make its way up into the cylinders and cause your problem
Old Apr 28, 2008 | 02:51 PM
atilla's Avatar
5 quarts is definitely too much.
when i had a misfire problem it turned out to be a clogged injector. i had to remove the fuel rail and clean the injectors. it's a good idea to run a bottle of fuel injector cleaner once in awhile to prevent that kind of issue.
X2jesse1x
Aug 8, 2017 05:51 PM
Tw3NTy0n3
Feb 17, 2017 08:57 PM
Danial81
Lancer Troubleshooting
Sep 8, 2016 09:31 PM
berkel
51
Apr 7, 2006 08:54 AM
IS2000
17
Nov 18, 2003 03:50 PM
